Indiana Jones and the Dial of Destiny 4K Invalid Request Error
piet.krn
#1 Post by piet.krn » Sat May 17, 2025 3:04 pm
Hi guys,
first of all I´m new to the forum, but I´m using MakeMKV for about 2 years now. Today I tried to rip Indiana Jones and the Dial of Destiny UHD, but it didn´t work. It can open the disc and it´s also working for about 15 minutes and then it stops with a couple of errors with the following message "SCSI Error - ILLEGAL REQUEST:INVALID FIELD IN CBD".
The disc was fresh out of the box and I am using MakeMKV 1.18.1 with an Asus BW-16D1HT drive which is flashed to 3.10 and LibreDrive enabled. The drive is also compatible to BDXL.
I´m now at a point where I don´t know how to fix the problem on my own and I hope that someone of you guys could help me! :)
Re: Indiana Jones and the Dial of Destiny 4K Invalid Request Error
#2 Post by MartyMcNuts » Sun May 18, 2025 12:16 am
piet.krn wrote: Sat May 17, 2025 3:04 pm Hi guys,
I´m not a point where I don´t know how to fix the problem on my own and I hope that someone of you guys could help me! :)
Clean the disc! This is especially important for brand new out of the box discs.
piet.krn
#3 Post by piet.krn » Sun May 18, 2025 8:50 pm
Thanks for the reply. Sadly it´s not the solution.
After a few more attempts I´ve got an additional Error now (MEDIUM ERROR:L-EC UNCORRECTABLE ERROR). I followed the MakeMKV suggestion to copy the disc manually, but even this process failed.
#4 Post by SamuriHL » Sun May 18, 2025 9:24 pm
Replace the disc or try a different drive.
piet.krn
#5 Post by piet.krn » Mon May 19, 2025 5:40 pm
Crazy crazy.. It finally worked.. with a second fully new disc. Thanks for the tip.
