No, the firmware has nothing to do with the region coding. MakeMKV should take care of that when ripping anyway.XTRProf wrote: Fri May 16, 2025 7:04 am Sorry for this noob question. Does the firmware 1.03 MK or in fact any jail broken firmwares make the drive now region free at least for DVDs. I know blurays and UHD blurays lately no such constraint on the number of region changes that can be made limited to 5 before the drive being locked into the last done region.
Thanks for any clarification.
Chong
Re: SDFtool Flasher
XTRProf
Re: SDFtool Flasher
Billycar11 wrote: Fri May 16, 2025 8:07 pmTake the disc out manXTRProf wrote: Fri May 16, 2025 7:36 am Sorry. Try to flash my second Verbatim 43888 but there is an error code message. How come?
Thanks.
Chong
Ha, didn't know. Everything in order now, sir! Now I have 2 fully jail broken Verbatim 43888 at 1.03 MK firmware version.
Thanks very much. Salute!
Chong
XTRProf
Re: SDFtool Flasher
MartyMcNuts wrote: Sat May 17, 2025 12:36 amNo, the firmware has nothing to do with the region coding. MakeMKV should take care of that when ripping anyway.XTRProf wrote: Fri May 16, 2025 7:04 am Sorry for this noob question. Does the firmware 1.03 MK or in fact any jail broken firmwares make the drive now region free at least for DVDs. I know blurays and UHD blurays lately no such constraint on the number of region changes that can be made limited to 5 before the drive being locked into the last done region.
Chong
Thanks and noted, man!
Chong
seatopian
Re: SDFtool Flasher
Hello, I just got my Archgon MD-8107S-U3-UHD, it was version 1.01, used the GUI to take it 1.03MK, then tested a disc.
No disc. Tried flashing to 1.00, no disc then too. Am I doing something wrong?
Re: SDFtool Flasher
Allow the OS to initialize the disc before opening MakeMKV.seatopian wrote: Sun May 18, 2025 6:31 pm Hello, I just got my Archgon MD-8107S-U3-UHD, it was version 1.01, used the GUI to take it 1.03MK, then tested a disc.
Ensure MakeMKV has internet access as this is needed to download the UHD hashed keys.
Clean the disc with a microfiber cloth.
seatopian
Re: SDFtool Flasher
Done all three, even tried another disc from the same set.MartyMcNuts wrote: Sun May 18, 2025 10:54 pmAllow the OS to initialize the disc before opening MakeMKV.seatopian wrote: Sun May 18, 2025 6:31 pm Hello, I just got my Archgon MD-8107S-U3-UHD, it was version 1.01, used the GUI to take it 1.03MK, then tested a disc.
Re: SDFtool Flasher
What disc set it it? If it's GoT or LotR, these are well known as notoriously bad quality disc pressings.seatopian wrote: Sun May 18, 2025 11:40 pmDone all three, even tried another disc from the same set.MartyMcNuts wrote: Sun May 18, 2025 10:54 pmAllow the OS to initialize the disc before opening MakeMKV.seatopian wrote: Sun May 18, 2025 6:31 pm Hello, I just got my Archgon MD-8107S-U3-UHD, it was version 1.01, used the GUI to take it 1.03MK, then tested a disc.
Can you see the disc in windows explorer?
Does a normal BD disc work?
seatopian
Re: SDFtool Flasher
German 4K of RoboCop.
Can't see the disc in explorer either. Normal BDs (even from the same set) work
Re: SDFtool Flasher
If BD's work, then the laser is fine. You may need to wash the UHD disc with soapy water and dry with a microfiber cloth. I'd then let it finish air drying overnight before testing it again. It's possible the disc may be faulty. Try another UHD disc.seatopian wrote: Mon May 19, 2025 4:47 am German 4K of RoboCop.
Also, it sounds silly but sometimes a drive just doesn't like a particular disc. It happens... This is one of the reasons why most of us have multiple drives.
seatopian
Re: SDFtool Flasher
Gotcha. For what it's worth, I also just now tried my US 4K of Alien and it's not reading either. Will try to clean all three tomorrow! Thanks for the help.
EDIT: a little bit after i posted this, i decided to double check and now it's stalling out on regular BD discs. think i got a faulty drive.
Re: SDFtool Flasher
Yeah, possibly. Maybe return it and get something else...seatopian wrote: Mon May 19, 2025 6:06 am Gotcha. For what it's worth, I also just now tried my US 4K of Alien and it's not reading either. Will try to clean all three tomorrow! Thanks for the help.
disneyvader
Re: SDFtool Flasher
im getting an error telling me i dont have MakeMKV installed but clearly i do what is happening here?
https://imgur.com/a/x9ZL1iH
zittrig
Re: SDFtool Flasher
Is MakeMKV installed to the default location?
disneyvader
Re: SDFtool Flasher
No i installed it on a different drive than my OS
I have tried running the software from the same location I installed MakeMKV
zittrig
Re: SDFtool Flasher
So install it to the default location and try again.
