Failure - "Awesome 80s Music Video Collection Vol.2"
jjnvdm
Post by jjnvdm »
The above disc fails right at the end. I've attached the necessary *.IFO and debug log files. When using PavTube ByteCopy it rips without problems. I've also checked the disc for marks or scratches and cleaned it - it is spotless. I've tried to copy it with MakeMKV 3 times and each time it fails.
Jaco
MakeMKV_log.zip
(668.38 KiB) Downloaded 735 times
Re: Failure - "Awesome 80s Music Video Collection Vol.2"
Post by mike admin »
A badly mastered disc, workaround should be added in the next version.
jjnvdm
Post by jjnvdm »
Thanks, that is good to hear. Any indication of when the next update will be released?
Today.
jjnvdm
Post by jjnvdm »
I downloaded and tried the latest version of MakeMKV (1.7.0) on this problematic DVD, but it still fails right at the end. I've attached the necessary debug files.
Please try this workaround - download attached file and place it into "MakeMKV data directory". Please post the result here. This workaround should work with any version after 1.6.16 .
reord-a80-v2.txt
(96 Bytes) Downloaded 716 times
jjnvdm
Post by jjnvdm »
I copied the file into my MakeMKV 1.7.0 data directory and ripped the DVD again. This time it worked, but with some warnings.
I also notice there is a v1.7.1 available. I'll try the problematic DVD with that version too and see if it works (I'll remove the file from the MakeMKV data directory first)
Here is the output from the log window:
MakeMKV v1.7.0 win(x86-release) started
Debug logging enabled, log will be saved as C:\Documents and Settings\Jaco/MakeMKV_log.txt
The new version 1.7.1 is available for download at http://www.makemkv.com/download
Title #0 was added (50 cell(s), 3:27:13)
Title #1 was added (50 cell(s), 3:27:13)
Title 2 in VTS 1 is equal to title 1 and was skipped
Saving 1 titles into directory M:/Video/AWESOME_80S_VOL_2
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 47347712, attempting to work around
DEBUG: Code 86400000 at )fq4!RefZ;J!R;X/. a:29393700
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 79755264, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 115251200, attempting to work around
The source file '/VIDEO_TS/VTS_01_1.VOB' is corrupt or invalid at offset 157571072, attempting to work around
1 titles saved
I've also attached the log file in case it helps
MakeMKV_log.txt
(5.32 KiB) Downloaded 696 times
