Pioneer BDR-UD03 UHD possibility
Re: Pioneer BDR-UD03 UHD possibility
abababab wrote: Sun May 11, 2025 3:17 am I've got one of these fellas, some assistance and potentially firmware would be much appreciated :)
Manufacturer: PIONEER
Product: BD-RW BDR-UD03
Revision: 1.14
Serial number: XXXXXXXXXXXX
Firmware date: 2020-06-15
Drive platform: RS8511
Firmware version: 1.14
PM sent.
TheTinderAccount wrote: Mon May 12, 2025 7:59 pm Hi y'all
Just bought a Verbatim USB3.1 Type-C Drive 43890
Does anyone know how to flash the drive so it can read UHD?
OS device name: H:
Revision: 1.14
Serial number: CIDL505149WL
Highest AACS version: 77
PM sent.
bloom wrote: Mon May 12, 2025 10:58 pm If possible, I would like to flash my drive as well. Thanks in advance.
OS device name: /dev/sr0
Revision: 1.03
Serial number: ...
Firmware date: 2015-05-14
Drive platform: RS8510
Firmware version: 1.03/ID19
PM sent.
CodeAX2
Post by CodeAX2 »
I would also like to flash my drive if possible. Thanks!
Revision: 1.14
Serial number: [Redacted]
Highest AACS version: 44
CodeAX2 wrote: Wed May 14, 2025 5:45 pm I would also like to flash my drive if possible. Thanks!
Revision: 1.14
PM sent.
Palladium
Post by Palladium »
hey just got a verbatim 43890 and I wanna flash it can you help me out?
Revision: 1.14
Serial number: ...
Highest AACS version: 63
Palladium wrote: Thu May 15, 2025 7:04 pm hey just got a verbatim 43890 and I wanna flash it can you help me out?
Revision: 1.14
Serial number: ...
Can you run Windows? Flasher is Windows only.
Palladium
Post by Palladium »
Coopervid wrote: Fri May 16, 2025 2:54 am
Revision: 1.14
Serial number: ...
the drive literally just died on me while ripping sorry but I don't think I'll need that firmware anymore
Palladium wrote: Fri May 16, 2025 5:13 pm
Revision: 1.14
Serial number: ...
Most likely the enclosure electronics died. Get a Benfei USB SATA adapter and a mini SATA adapter and try.
rrj_ok
Post by rrj_ok »
I would like to flash my drive. Any help I would greatly appreciate it. Thanks in advance!
Revision: 1.14
Serial number: ...
spooky_dot
Post by spooky_dot »
I would also like to flash my drive, have had it for a while but didn't know that something like this was required for working with UHD Media
OS device name: H:
Revision: 1.11
Serial number: ...
Firmware date: 2018-11-28
Firmware version: 1.11
spooky_dot wrote: Mon May 19, 2025 6:36 pm Hello,
OS device name: H:
Revision: 1.11
Serial number: ...
PM sent.
PawPawRip
Post by PawPawRip »
I luckily found one of these drives on Ebay!
Can I also kindly ask for help to get this flashed to read UHD discs?
(I can plug this into a Windows workstation to flash if needed)
Thank you!
OS device name: /dev/rdisk5
Revision: 1.01
Serial number:
Firmware date: 2014-02-25
Drive platform: Pioneer RS8510
Firmware version: ID19
PawPawRip wrote: Tue May 20, 2025 9:34 pm Hi,
Thank you!
Revision: 1.01
Serial number:
PM sent.
mali40
Post by mali40 »
I read that you can flash it to read UHD discs?
How do I do that?
I have a verbatim 43889.
Vann you help me please?
Laufwerksinformation
OS-Gerätename: D:
Produzent: PIONEER
Produkt: BD-RW BDR-UD03
Revision: 1.14
Serienummer: xxxxxxxxxxx
Firmware-Datum: 2020-06-15
Highest AACS version: 81
Keine Disk eingelegt
