Hello
I am trying to decrypt a 4k UDH Spiderman no way home and it keeps throwing an error that it cant decrypt it. Below is the list of errors that are coming up.
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..03F to device 'SG:dev_21:13'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..0020..03F to device 'SG:dev_21:13'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..07F to device 'SG:dev_21:13'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..0020..07F to device 'SG:dev_21:13'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..0BF to device 'SG:dev_21:13'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..0020..0BF to device 'SG:dev_21:13'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A30..0020..0FF to device 'SG:dev_21:13'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT PRESENT' occurred while issuing SCSI command A40..0020..0FF to device
Backup failed
Cant decrypt 4k UHD
Re: Cant decrypt 4k UHD
That's the relevant bit from the log. The optical drive has to support LibreDrive to be able to rip UHDs.
Please post the MakeMKV details about your drive. Hopefully the firmware can be flashed to support LibreDrive. There's a well maintained guide for flashing: Ultimate UHD Drives Flashing Guide
Thanks for the support. I am new to this so please bear with me. Details from makemkv below
OS device name: /dev/sr4
Product: BD-RE BP60NB10
Revision: 1.02
Serial number: SIM03P2AG2415
Firmware date: 2121-07-08 15:56
Highest AACS version: 18
Harware support: Yes
Firmware support: No
Firmware version: 1.02
Revision: 1.02
I posted the drive info below. Do I need to flash the drive?
Revision: 1.02
Serial number: ...
Revision: 1.02
Serial number: ...
Libredrive must be enabled to be able to read UHD discs, so yes, you must flash it.rubiks1 wrote: ↑Wed May 14, 2025 4:12 pmThanks for the support. I am new to this so please bear with me. Details from makemkv below
Revision: 1.02
I assume your drive has SVC NB12 on the sticker underneath? If so, flash it with BP60NB10 NB12 1.02-MK and you are good to go!
