This disc uses newer version of AACS protection. Please let us know about it by visiting
Please add the dump file
TLVD_0001 Blu-ray: AACS v82 – Volume key missing
- MKB_v82_tayori_1st_Live_春を待つ_追加公演_23B4.tgz
- (88.88 KiB) Downloaded 432 times
Re: TLVD_0001 Blu-ray: AACS v82 – Volume key missing
Your key is in the keydb. Either download and extract it to your MakeMKV data directory, or if you're on windows you can use my tool which will use FindVUK to synchronize it and copy it to your MakeMKV data directory for you. Additionally if you follow the directions in my post, you can handle future titles automatically.
viewtopic.php?f=12&t=16883&p=166510#p166510
