Submitting the dumps for Dune Prophecy Season 1 4K UHD from the UK Steelbook release. Sent the email but also uploading here for the keydb.
Dune Prophecy Season 1 4K UHD (UK Steelbook) Dump Submitted
TCBuckeye
keydb_helper
Re: Dune Prophecy Season 1 4K UHD (UK Steelbook) Dump Submitted
Thanks for providing the disc dump files, it is really appreciated. All three of your discs have been supported by the public keydb since May 8.TCBuckeye wrote: Mon May 12, 2025 9:15 pm Submitting the dumps for Dune Prophecy Season 1 4K UHD from the UK Steelbook release. Sent the email but also uploading here for the keydb.
MKB20_v77_Dune-_Prophecy_-_Season_1_Disc_1_F280.tgz
MKB20_v77_Dune-_Prophecy_-_Season_1_Disc_2_219C.tgz
MKB20_v77_Dune-_Prophecy_-_Season_1_Disc_3_ADFC.tgz
Public KeyDB Disc Submissions
- The MKB_RO.inf file from the original disc is required
- Do not submit Stranger Things
TCBuckeye
I’ve downloaded the most recent KEYDB.cfg file and placed it in the MakeMKV folder, and also verified MakeMKV is allowed internet access. I’m still getting the “The volume key is unknown for this disc - video can’t be decrypted” error message. Are there any other fixes I should try?
if you're on windows try my tool to ensure everything is in the right place:TCBuckeye wrote: Tue May 13, 2025 3:33 pm I’ve downloaded the most recent KEYDB.cfg file and placed it in the MakeMKV folder, and also verified MakeMKV is allowed internet access. I’m still getting the “The volume key is unknown for this disc - video can’t be decrypted” error message. Are there any other fixes I should try?
viewtopic.php?f=12&t=16883&p=166510#p166510
TCBuckeye
This worked perfectly. Thank you!!
