Dump Submitted for:
THE CRAZIES (2010) 4K UHD Lionsgate Limited Release, May 2025
MKB20_v77_The_Crazies_0F62.tgz
TGZ file modified: Friday, May 9, 2025, 5:10:58 PM
Dump Submitted - The Crazies (2010) Lionsgate Limited 4K May 2025
cerealpimp73
cerealpimp73
Curtis Bartlett
- Contact:
Re: Dump Submitted - The Crazies (2010) Lionsgate Limited 4K May 2025
Can you give me more detailed instructions on how to use this file?
You don't. It's a dump file containing information needed to generated the vuk and unit keys. Hopefully someone can use it to add the entry to the keydb if it doesn't already exist. If you have your own dump file created by makemkv you can post it here but also make sure to send it to the svq email address so that makemkv can also add the key to the internal hashed keys.
keydb_helper
The 0F62 variant of The Crazies has been added to the public keydb.
If you haven't previously configured MakeMKV to utilise the public keydb you can follow my instructions here or use SamuriHL's utility for Windows (Link)
Public KeyDB Disc Submissions
cerealpimp73
Excellent! Thanks for the heads-up!keydb_helper wrote: Mon May 12, 2025 10:34 pm The 0F62 variant of The Crazies has been added to the public keydb.
keydb_helper
No problem.
If you have a UHD compatible LG or Asus drive I would recommend using it to create disc dump files in the future. Disc dump files produced by Pioneer drives are well supported by the MakeMKV team but they are less helpful from a public keydb perspective.
cerealpimp73
Good to know….Actually, I DO have access to an LG drive. I’ll try to use it for any future public dump file posts. Thanks.keydb_helper wrote: Mon May 12, 2025 11:43 pmNo problem.
