Dump Submitted - The Crazies (2010) Lionsgate Limited 4K May 2025
cerealpimp73
Post by cerealpimp73 » Fri May 09, 2025 10:22 pm
Dump Submitted for:
THE CRAZIES (2010) 4K UHD Lionsgate Limited Release, May 2025
MKB20_v77_The_Crazies_0F62.tgz
TGZ file modified: Friday, ‎May ‎9, ‎2025, ‏‎5:10:58 PM
cerealpimp73
Re: Dump Submitted - The Crazies (2010) Lionsgate Limited 4K May 2025
Post by cerealpimp73 » Sat May 10, 2025 5:20 pm
File attached
Curtis Bartlett
Post by Curtis Bartlett » Mon May 12, 2025 3:13 am
Can you give me more detailed instructions on how to use this file?
Post by SamuriHL » Mon May 12, 2025 9:36 am
You don't. It's a dump file containing information needed to generated the vuk and unit keys. Hopefully someone can use it to add the entry to the keydb if it doesn't already exist. If you have your own dump file created by makemkv you can post it here but also make sure to send it to the svq email address so that makemkv can also add the key to the internal hashed keys.
keydb_helper
Post by keydb_helper » Mon May 12, 2025 10:34 pm
The 0F62 variant of The Crazies has been added to the public keydb.
If you haven't previously configured MakeMKV to utilise the public keydb you can follow my instructions here or use SamuriHL's utility for Windows (Link)
Public KeyDB Disc Submissions
cerealpimp73
Post by cerealpimp73 » Mon May 12, 2025 10:48 pm
Excellent! Thanks for the heads-up!
keydb_helper
Post by keydb_helper » Mon May 12, 2025 11:43 pm
No problem.
If you have a UHD compatible LG or Asus drive I would recommend using it to create disc dump files in the future. Disc dump files produced by Pioneer drives are well supported by the MakeMKV team but they are less helpful from a public keydb perspective.
cerealpimp73
Post by cerealpimp73 » Mon May 12, 2025 11:52 pm
No problem.
Good to know….Actually, I DO have access to an LG drive. I’ll try to use it for any future public dump file posts. Thanks.
