Hello.
I have just bought a new Hitachi-LG slim portable Blu-ray writer. The drive details are :
SVC Code: EB52
Product: BD-RE BP55EB40
Revision: 1.03
Serial number: SIK
Firmware date: 2121-07-08 16:06
I would like to ‘update’ the firmware to take advantage of LibreDrive, I have read so many threads on how to achieve this that I have now become rather confused. I would appreciate it if some kind person could check my plan of action to make sure it is correct, before I do it.
Using SDFtool Flasher (v1.3.6) -
1. Flash drive to BP55EB40-NB50-1.03 from MK firmware pack
2. Choose recover drive in tool,
When prompted, select BP55EB40-NB50-1.03 (same file as in step 1)
Then in ‘firmware to write’ select DE_LG_BU40N_1.00 from All you need firmware pack.
Many thanks in advance for your help.
Neal Walker.
Hitachi-LG USB Blu-ray Drive BP55EB40 SVC EB52
regatta
Re: Hitachi-LG USB Blu-ray Drive BP55EB40 SVC EB52
Correct.regatta wrote: Fri May 09, 2025 9:34 am Hello.
SVC Code: EB52
Revision: 1.03
Serial number: SIK
Neal Walker.
regatta
Thank you so much for your help. Mission accomplished
Product: BD-RE BU40N
Revision: 1.00
Serial number: SIK
Firmware date: 2116-12-20 15:28
Firmware version: 1.00
Revision: 1.00
Serial number: SIK
fileflirter
hi, i cant seem to find the DE_LG_BU40N_1.00 firmware; its not present in the mk-firmware-pack-20200720.
Can some1 pls provide me with a dl link?
I read that dvdfab only works with this 1.00 firmware.
It's in the de pack in the guidefileflirter wrote: Sun Feb 01, 2026 5:15 pm hi, i cant seem to find the DE_LG_BU40N_1.00 firmware; its not present in the mk-firmware-pack-20200720.
zittrig
I've my first EB52 for flashing here. I thought I do some experimental with it. Just flashed to LG BU40N 1.03MK like the EB40.....and 4K ripping is fine.
Why is the the second step to 1.00 necessary with the EB52?
It's not for Makemkv / AnyDVD / XReveal. Only if you want to use DVDFab / Passkey.zittrig wrote: Tue Feb 24, 2026 5:41 pm I've my first EB52 for flashing here. I thought I do some experimental with it. Just flashed to LG BU40N 1.03MK like the EB40.....and 4K ripping is fine.
zittrig
Yeah, the 1.00 compatibility with DVDFab is known. But I thought for the EB52 there is a special reason for this. Or does that only apply to the WP/BP50NB40 with SVC EB52?Coopervid wrote: Tue Feb 24, 2026 7:50 pmIt's not for Makemkv / AnyDVD / XReveal. Only if you want to use DVDFab / Passkey.zittrig wrote: Tue Feb 24, 2026 5:41 pm I've my first EB52 for flashing here. I thought I do some experimental with it. Just flashed to LG BU40N 1.03MK like the EB40.....and 4K ripping is fine.
No special reason.zittrig wrote: Tue Feb 24, 2026 8:35 pmYeah, the 1.00 compatibility with DVDFab is known. But I thought for the EB52 there is a special reason for this. Or does that only apply to the WP/BP50NB40 with SVC EB52?Coopervid wrote: Tue Feb 24, 2026 7:50 pmIt's not for Makemkv / AnyDVD / XReveal. Only if you want to use DVDFab / Passkey.zittrig wrote: Tue Feb 24, 2026 5:41 pm I've my first EB52 for flashing here. I thought I do some experimental with it. Just flashed to LG BU40N 1.03MK like the EB40.....and 4K ripping is fine.
zittrig
Ok, thank you!Coopervid wrote: Tue Feb 24, 2026 8:36 pmNo special reason.zittrig wrote: Tue Feb 24, 2026 8:35 pmYeah, the 1.00 compatibility with DVDFab is known. But I thought for the EB52 there is a special reason for this. Or does that only apply to the WP/BP50NB40 with SVC EB52?Coopervid wrote: Tue Feb 24, 2026 7:50 pm
Duke90
Hi, I bought exactly the same drive as you with all parameters you specified and I followed all your steps to flash the firmware. I did exactly what you did, but I still cannot read UHD disks.regatta wrote: Fri May 09, 2025 9:34 am Hello.
SVC Code: EB52
Revision: 1.03
Serial number: SIK
Neal Walker.
This are my parameters now after flash:
Revision: 1.03
Serial number: SIK0EO1NG4823
Firmware date: 2120-05-07 09:24
Firmware version: 1.03
Could you please tell me what I possibly did wrong? Maybe the "include boot" option must be ticked? Many thanks in advance for you answer!
Michael
Sayaka
It looks like something went wrong, and only the first step succeeded. No need to tick "include boot loader". No need to tick "encrypted firmware" either, at this point.Firmware type: Patched (microcode access re-enabled)
You need to follow these exact steps :
First, remove the disc that's inside the drive if there is one. Then start SDFtool flasher, select your drive in the upper drop-down menu, and select RECOVER Drive.
You will be asked to select a file. Select the file that starts with "HL-DT-ST-BD-RE_BP55EB40-NB50-1.03" inside the BP55EB40-NB50 folder of the mk firmware pack.
Do *not* click on START yet. Next, click on the lower drop-down menu, and select DE_LG_BU40N_1.00.bin from Marty's All You Need Firmware pack. Although if you don't care much about DVDFab compatibility, you might want to select DE_LG_BP60NB10_1.00_MK.bin instead for this second step. It has much less trouble with difficult discs, in my experience.
Click on START. Wait until the operation finishes (wait until SDFtool flasher says "Ready" again, then you can click on "EXIT").
Power cycle the drive afterwards (this can be done by unplugging it, waiting 30 seconds or so and re-plugging it). Then try inserting/ripping a UHD disc again, and please let us know how it goes.
EDIT : In the first version of my post, I implied that the DE_LG_BP60NB10_1.00_MK.bin firmware isn't Linux-compatible. This was a mistake on my part due to lack of sleep.
see guide below you missed the multi step flashing steps it looks likeDuke90 wrote: Tue May 05, 2026 4:52 pmHi, I bought exactly the same drive as you with all parameters you specified and I followed all your steps to flash the firmware. I did exactly what you did, but I still cannot read UHD disks.regatta wrote: Fri May 09, 2025 9:34 am Hello.
SVC Code: EB52
Revision: 1.03
Serial number: SIK
Neal Walker.
Revision: 1.03
Michael
or get an auto flasher from me or marty that does all the work for you
