Hitachi-LG USB Blu-ray Drive BP55EB40 SVC EB52
regatta
Post by regatta »
Hello.
I have just bought a new Hitachi-LG slim portable Blu-ray writer. The drive details are :
SVC Code: EB52
Product: BD-RE BP55EB40
Revision: 1.03
Serial number: SIK
Firmware date: 2121-07-08 16:06
I would like to ‘update’ the firmware to take advantage of LibreDrive, I have read so many threads on how to achieve this that I have now become rather confused. I would appreciate it if some kind person could check my plan of action to make sure it is correct, before I do it.
Using SDFtool Flasher (v1.3.6) -
1. Flash drive to BP55EB40-NB50-1.03 from MK firmware pack
2. Choose recover drive in tool,
When prompted, select BP55EB40-NB50-1.03 (same file as in step 1)
Then in ‘firmware to write’ select DE_LG_BU40N_1.00 from All you need firmware pack.
Many thanks in advance for your help.
Neal Walker.
Re: Hitachi-LG USB Blu-ray Drive BP55EB40 SVC EB52
regatta wrote:
Fri May 09, 2025 9:34 am
Hello.
SVC Code: EB52
Revision: 1.03
Serial number: SIK
Neal Walker.
Correct.
regatta
Post by regatta »
Thank you so much for your help. Mission accomplished :)
Product: BD-RE BU40N
Revision: 1.00
Serial number: SIK
Firmware date: 2116-12-20 15:28
Firmware version: 1.00
fileflirter
Post by fileflirter »
hi, i cant seem to find the DE_LG_BU40N_1.00 firmware; its not present in the mk-firmware-pack-20200720.
Can some1 pls provide me with a dl link?
I read that dvdfab only works with this 1.00 firmware.
fileflirter wrote:
Sun Feb 01, 2026 5:15 pm
It's in the de pack in the guide
zittrig
Post by zittrig »
I've my first EB52 for flashing here. I thought I do some experimental with it. Just flashed to LG BU40N 1.03MK like the EB40.....and 4K ripping is fine.
Why is the the second step to 1.00 necessary with the EB52?
zittrig wrote:
Tue Feb 24, 2026 5:41 pm
It's not for Makemkv / AnyDVD / XReveal. Only if you want to use DVDFab / Passkey.
zittrig
Post by zittrig »
Coopervid wrote:
Tue Feb 24, 2026 7:50 pm
Yeah, the 1.00 compatibility with DVDFab is known. But I thought for the EB52 there is a special reason for this. Or does that only apply to the WP/BP50NB40 with SVC EB52?
zittrig wrote:
Tue Feb 24, 2026 8:35 pm
No special reason.
zittrig
Post by zittrig »
Coopervid wrote:
Tue Feb 24, 2026 8:36 pm
No special reason.
Ok, thank you! :)
