Questions:
1) Do I need to change the ":5086"? It seems like it is a name or ID, and maybe I do not want it the same as the default profile?
2) Will it make any difference if I change "ignoreForcedSubtitlesFlag" to "false"? It seemed like Mike was saying that some output settings are not yet implemented.
<?xml version="1.0" encoding="utf-8"?>
<profile>
<name lang="eng">myprofile</name>
<!-- Common MKV flags -->
<mkvSettings ignoreForcedSubtitlesFlag="true" />
<!-- Output formats currently supported by MakeMKV -->
<outputSettings name="discard" outputFormat="discard">
<description lang="eng">Discard track</description>
</outputSettings>
<outputSettings name="copy" outputFormat="directCopy">
<description lang="eng">Copy track as is</description>
</outputSettings>
<outputSettings name="lpcm" outputFormat="LPCM-raw">
<description lang="eng">Save as raw LPCM</description>
<channelOrder>L,R</channelOrder>
<byteOrder>big</byteOrder>
</outputSettings>
<outputSettings name="wavex" outputFormat="LPCM-wavex">
<description lang="eng">Save as LPCM in WAV container</description>
</outputSettings>
<!-- Default rule - copy as is -->
<trackSettings input="default">
<output outputSettingsName="copy"
defaultSelection="-all,+favlang,+nolang,-havemulti,-havelossless,+core">
</output>
</trackSettings>
<!-- Save LPCM mono or stereo as raw LPCM -->
<trackSettings input="LPCM-stereo">
<output outputSettingsName="lpcm"
</output>
</trackSettings>
<!-- Put multi-channel LPCM into WAVEX container-->
<trackSettings input="LPCM-multi">
<output outputSettingsName="wavex"
</output>
</trackSettings>
</profile>
