MKV Files and HDR
leosantare
MKV Files and HDR
Post by leosantare »
When I rip a 4K UHD blu-ray in makemkv, does the mkv file actually have HDR? For example, the picture appears exactly the same in VLC player if HDR is enabled or not in Windows. When I enable HDR in Windows, I can see the change in Windows. Plus, my display briefly shows the signal has changed to HDR mode. However, there is no difference when playing a mkv file in VLC.
Re: MKV Files and HDR
If you look at the .mkv file with MediaInfo, the video section will list if the file has Dolby Vision and/or HDR10. For example, here's a movie with only HDR10:
Video
ID in the original source medium         : 4113 (0x1011)
HDR format                               : SMPTE ST 2086, HDR10 compatible
Duration                                 : 1 h 57 min
Bit rate                                 : 50.8 Mb/s
Bits/(Pixel*Frame)                       : 0.256
Stream size                              : 41.7 GiB (93%)
Maximum Content Light Level              : 1376 cd/m2
Maximum Frame-Average Light Level        : 731 cd/m2
and here's an example with both:
Video
HDR format                               : Dolby Vision, Version 1.0, Profile 7.6, dvhe.07.06, BL+EL+RPU, no metadata compression, Blu-ray compatible / SMPTE ST 2086, Version HDR10, HDR10 compatible
Duration                                 : 1 h 47 min
Bit rate                                 : 100 Mb/s
Bits/(Pixel*Frame)                       : 0.504
Stream size                              : 75.2 GiB (95%)
Maximum Content Light Level              : 7130 cd/m2
Maximum Frame-Average Light Level        : 545 cd/m2
I don't really use Windows or VLC so I can't really make suggestions about them.
leosantare
Okay, well hopefully someone can help with Windows and VLC.
leosantare
Why isnt there a difference if hdr is enabled in windows or not when playing a mkv in vlc?
Ezatoka
Post by Ezatoka »
I don't know for sure, but maybe VLC automatically issues some tonemapping if it finds a HDR source with a non-HDR display.
leosantare
I'm not sure what you mean by that. I know my display is not in HDR unless I enable it in Windows. Like I said, there is no difference in the picture if HDR is enabled in Windows. I understand VLC supports HDR and dcoke22 confirmed that mkv files contain HDR.
Mr. Red
Post by Mr. Red »
You could try MPC-HC with MPC Video Renderer instead of VLC.
smol_birb
Post by smol_birb »
leosantare wrote:
Tue May 06, 2025 12:39 am
Windows will have the option to enable HDR, even if the display doesn't support HDR. Does your display support HDR?
Mutato
Post by Mutato »
MPC-HC player with madVR Renderer and you need display with HDR support, check hardware specifications, user manual.
leosantare
When I had a display that did not support HDR, I could not enable HDR in Windows. Now, that I have a display that supports HDR, I can enable HDR in Windows.
Okay, I will try MPC-HC with madVR.
Thank you,
