Problem specific to DVD and ISO files
xaviour
Post by xaviour »
Life of Brian (PAL, Region 2) part of "Monty Python Almost Everything Boxset"
Sony Pictures Home
MakeMKV 1.7.0 is successful when dealing with the directory structures but
fails when dealing with a block device (either DVD or ISO files). Here is a resume
of what has been tried:
DVD -> MakeMKV -> Failure
DVD -> DVDFab 8.1.3.8 -> VIDEO_TS -> MakeMKV -> Success
DVD -> DVDFab 8.1.3.8 + Nero -> ISO -> MakeMKV -> Failure
DVD -> DVDFab 8.1.3.8 + Nero -> ISO -> VIDEO_TS -> MakeMKV -> Success
The logs of MakeMKV and DVDFab have been attached to this post.
xaviour
Re: Problem specific to DVD and ISO files
Post by xaviour »
And here are the log files.
Riplogs.zip
Log files of MakeMKV and DVDFab for the 4 cases.
(10.36 KiB) Downloaded 772 times
setarip_old
Post by setarip_old »
Hi!
If you haven't already tried this, perform the same sequences BUT DON'T MOUNT the .ISO image file - just load the .ISO image file directly into MakeMKV...
xaviour
Post by xaviour »
setarip_old wrote:just load the .ISO image file directly into MakeMKV...
Yes, this has already been tested. It is the third case.
Post by mike admin »
Can you please make a testdump per instructions at http://www.makemkv.com/onlinehelp/testdump.html . It might fail as well, in this case please at least sumbit all IFO files from the disc.
Thank you.
xaviour
Post by xaviour »
Sent extra debug information to mike.
xaviour
Post by xaviour »
Using MakeMKV v1.7.1,
- The ISO image is ripped successfully.
- The DVD still fails.
crowfax
Post by crowfax »
Have you sent the new logfiles and testdump made with 1.7.1?
xaviour
Post by xaviour »
Yes I did.
xaviour
Post by xaviour »
The problem is still present with 1.7.4.
MakeMKV_log.txt
Log file for 1.7.4.
(13.25 KiB) Downloaded 769 times
