2Close
#2926 Post by 2Close » Thu May 08, 2025 6:06 pm
jatenk wrote: Thu May 08, 2025 3:41 am
2Close wrote: Mon May 05, 2025 5:06 pm Hey Guys,
iam new to saving blurays and got a new verbatim 43888 from amazon:
OS device name: F:
Product: BD-RE BU40N
Revision: 1.05
Serial number: ...
Highest AACS version: 36
I've read the Ultimate UHD Drive Falsing Guide 2025 and downloaded the firmware files but am unsure what are the correct files for enabling libredrive.
Thanks very much for your help :)
I just got the same drive with most information the same, except "Highest AACS version" saying 81 in my case (and I'm using macOS, so OS device name corresponds to that). I also can't find the mentioned file HL-DT-ST-BD-RE_BU40N-1.03-NM00000-211810241934.bin in the current pack. What should I use? I'm sorry if this is supposed to be obvious.
It was here: https://drive.google.com/file/d/1HRnbXi ... sp=sharing
But i cant say, if its the right one for you.
nicholfd
#2927 Post by nicholfd » Thu May 08, 2025 11:49 pm
I just realized I had two old drives in an old, 2010 cheese grater Mac Pro (non-operable). Both are the same model: WH16NS40. I pulled one & put it in a Windows machine:
C:\Program Files (x86)\MakeMKV>makemkvcon64.exe f -l
Found 2 drives (s)
00: \Device\CdRom0, \Device\CdRom0, D:
  HL-DT-ST_BD-RE__WH16NS40_1.00_211304041441_K9AE5983418
MakeMKV Info:
Drive Info.png (88.06 KiB) Viewed 29237 times
I thought I would be able to flash it to read UHD discs & tried with this:
C:\Program Files (x86)\MakeMKV\makemkvcon64.exe f --all-yes -d E: rawflash -i c:\Users\nicholfd\Desktop\HL-DT-ST-BD-RE_WH16NS60-1.02-NM00100-211810291936. bin
No drive tool logic found in SDF.bin
Internal error 0x8d000000
-------- PROGRESS --------
Wrong drive letter in the flash command (I know - details matter). Tried again. Did something, but eventually failed (after long delay):
Drive Flash Failure.png (173.52 KiB) Viewed 29219 times
Shutdown, removed power, reapplied power & turned back on. MakeMKV now shows:
Drive Info After Failed Flash.png (29.13 KiB) Viewed 29219 times
Have I FUBAR'd this drive? I still have the 2nd one...
#2928 Post by Billycar11 » Fri May 09, 2025 12:53 am
nicholfd wrote: Thu May 08, 2025 11:49 pm I just realized I had two old drives in an old, 2010 cheese grater Mac Pro (non-operable). Both are the same model: WH16NS40. I pulled one & put it in a Windows machine:
Found 2 drives (s)
MakeMKV Info:
Is this drive not flash-able? Did I miss step or option?
do not flash it
nicholfd
#2929 Post by nicholfd » Fri May 09, 2025 12:59 am
Billycar11 wrote: Fri May 09, 2025 12:53 am
do not flash it
Thanks - too late. I found an issue & tried again. Thought I made progress. I updated my original message before you posted this one or they crossed. Is it hosed?
#2930 Post by Billycar11 » Fri May 09, 2025 1:07 am
nicholfd wrote: Fri May 09, 2025 12:59 am
do not flash it
dead unless you have a pc with sata ide mode and a 32bit os
see recovery section in guide
i no longer give out kits for these was way to much trouble as know one tells the truth about their pcs
nicholfd
#2931 Post by nicholfd » Fri May 09, 2025 1:26 am
Billycar11 wrote: Fri May 09, 2025 1:07 am
do not flash it
Thanks - the PC I moved the drive to is a "utility" PC, and to flash the drive I installed fresh Windows 10 64-bit (left unlicensed). I have a MSDN subscription & it looks like the 32-bit version of Windows 10 is still available (downloading now). What do I need to look for/at in the BIOS, or what information can I share to find out if the motherboard supports "SATA IDE mode"? I'm not sure I've ever heard of that.
Looking for the recover guide section now...
Or, is this drive not worth trying to recover (your time - I don't mind wasting my time playing with it)? I only wanted to mess with it as a backup for UHD discs. If it can be recovered & flashed to read UHD discs, I'm glad to make a PayPal donation. I'm sure I used it many years ago for DVD/BR. I probably abandoned it when/if it could not manage UHD (at the time). The Mac Pro it's been in has been out of use for probably 10 years...
nicholfd
#2932 Post by nicholfd » Fri May 09, 2025 2:13 am
Motherboard supports IDE mode
MB BIOS.png (113.95 KiB) Viewed 29185 times
Windows 10 x86 (32-bit) installed, with BIOS set to SATA IDE mode.
Win 10 Info.png (9.65 KiB) Viewed 29171 times
#2933 Post by MartyMcNuts » Fri May 09, 2025 5:26 am
OS device name: F:
Revision: 1.05
Serial number: ...
It's in the MK/old folder in the firmware pack.
#2934 Post by Billycar11 » Fri May 09, 2025 10:15 am
nicholfd wrote: Fri May 09, 2025 2:13 am Motherboard supports IDE mode
follow the recovery section and my dosflash video do the recovery stuff first make sure to do the steps exactly or dos flash wont work
as i said i dont do kits for this anymore more time than its worth everything you need is in the guide and my old dosflash video from 2019
jatenk
#2935 Post by jatenk » Fri May 09, 2025 11:11 pm
MartyMcNuts wrote: Fri May 09, 2025 5:26 am It's in the MK/old folder in the firmware pack.
Oh yeah, that's right, thanks! Can I use it safely to flash the drive though? What's the significance in the AACS-version difference?
#2936 Post by MartyMcNuts » Fri May 09, 2025 11:40 pm
jatenk wrote: Fri May 09, 2025 11:11 pm
The firmware has absolutley nothing at all to do with the AACS version of the drive.
When you insert a BD disc that has a higher AACS revision (happens on some new releases), it will automatically update the drive's revocation lists and you will notice the highest AACS version change to that of the BD disc.
jatenk
#2937 Post by jatenk » Sat May 10, 2025 12:03 am
MartyMcNuts wrote: Fri May 09, 2025 11:40 pm
Alright, so just to make sure I got this correctly, I sidegrade my Verbatim drive to BU40N 1.03 in MK/old, and then enc-flash according to step 7 in the top post manual, correct?
#2938 Post by MartyMcNuts » Sat May 10, 2025 1:52 am
jatenk wrote: Sat May 10, 2025 12:03 am
What?!?
Your Verbatim should be a BU40N drive with 1.05 on it. There's no trick to flashing it. Just use SDFTool flasher and flash it directly to BU40N 1.03-MK (we call all firmware in the pack "MK" as it's far easier than NM000343.....) first, which will remove the firmware encryption and the drive is now ready for use with MakeMKV. If you also want to use other ripping software such as DVDFab etc, then you can flash it to DE BU40N 1.00.
jatenk
#2939 Post by jatenk » Sat May 10, 2025 2:02 am
MartyMcNuts wrote: Sat May 10, 2025 1:52 am
What?!?
I can't use the GUI SDFTool since I'm on macOS, but I'm okey with using Terminal. So just side-grading it to 1.03 (from MK/old) will be enough to make it usable and able to rip UHD movies already? Sorry for my slow uptake - english isn't my first language.
#2940 Post by MartyMcNuts » Sat May 10, 2025 2:06 am
jatenk wrote: Sat May 10, 2025 2:02 am
What?!?
ah, ok. there's no side-grade. You are using the same model firmware at all times.
Yes, use firmware BU40N 1.03-MK from the MK/old folder and make sure you have rawflash enc in your command. Once the drive has been flashed and shows as firmware BU40N 1.03 you are done and can start using it to rip your UHD discs.
