Verbatim 43890 External Slimline Mobile USB 3.2 Blu-ray Writer UHD Problem
Re: Verbatim 43890 External Slimline Mobile USB 3.2 Blu-ray Writer UHD Problem
#211 Post by Coopervid » Fri May 02, 2025 8:59 am
babywinchester wrote:
Fri May 02, 2025 4:26 am
Hey Coopervid
I have the same drive as well and need your help in reading UHD
please can you help me with the same would be obliged really
Post your Makemkv info.
blottrot97
#212 Post by blottrot97 » Sat May 03, 2025 12:34 am
Coopervid, hoping you can help me enable UHD
Manufacturer: PIONEER
Product: BD-RW BDR-UD03
Revision: 1.14
Serial number: ,,,
Firmware date: 2020-06-15
Highest AACS version: 68
Drive platform: RS8511
Firmware version: 1.14
jncarlos
#213 Post by jncarlos » Sat May 03, 2025 3:14 am
Afternoon gents! Im so glad I found this thread. Mr. Coopervid if you are kind enough, I just got myself this drive the 43890 with the Pioneer drive and would love some help. Thanks in advance!! My drive has all same variables as the rest of the drives here.
#214 Post by Coopervid » Sat May 03, 2025 10:08 am
Revision: 1.14
Serial number: ,,,
PM sent.
Noahx04
#215 Post by Noahx04 » Tue May 06, 2025 9:34 am
Hey Coopervid :)
Have also a big problem. My device isnt burning newer Mdiscs. At leading in its saying power calibration error.
This are my informations:
Device
Firmware Version:
[0:0:0] PIONEER BD-RW BDR-UD03 1.11 (D:) (USB)
1.11 (Kernel Version: GENERAL)
Vendor Specific Info:
18/11/28 PIONEER
Serial Number: xxxx
Buffer Size: 4000 KiB
Thanks in advance! :D
glicocurry679
#216 Post by glicocurry679 » Wed May 07, 2025 9:01 pm
Hi, I just got this drive with these information:
Revision: 1.14
Serial number:
Highest AACS version: 75
Can this become a drive tht reads uhd?
Thanks in advance
#217 Post by Coopervid » Wed May 07, 2025 10:13 pm
Hey Coopervid :)
Device
Firmware Version:
18/11/28 PIONEER
Serial Number: xxxx
PM sent. M-Discs should work then.
#218 Post by Coopervid » Wed May 07, 2025 10:15 pm
Revision: 1.14
Serial number:
Thanks in advance
PM sent.
nachom10
#219 Post by nachom10 » Thu May 08, 2025 4:18 pm
Hi Coopervid,
Thank you for helping us with our 43890 drives. Can I get your help on drive to be able to support UHD?. Thanks.
Here's my drive info:
Revision: 1.14
Serial number: ...
woifi
#220 Post by woifi » Thu May 08, 2025 4:25 pm
Hi Coopervid,
thx for your service here :D
Can you send me the right firmware for my drive, please?
Verbatim 43890
PIONEER_BD-RW___BDR-UD031
OS-Gerätename: E:
Produzent: HL-DT-ST
Produkt: DVDRAM GH24NSB0
Revision: LN00
Serienummer: KZED8G93747
Firmware-Datum: 2013-07-31 14:48
woifi
#221 Post by woifi » Thu May 08, 2025 4:29 pm
Sry, that was the wrong details.
This are the right ones:
Laufwerksinformation
OS-Gerätename: \Device\CdRom1
Aktuelles Profil: DVD-ROM
Produzent: PIONEER
Produkt: BD-RW BDR-UD03
Revision: 1.10
Serienummer: ...
Firmware-Datum: 2017-04-18
Firmware version: 1.10
nachom10
#222 Post by nachom10 » Tue May 13, 2025 5:27 am
Hi Coopervid!
Please, can you help me?.
I would like to update the firmware and unlock UHD drives. Thanks in advance.
#223 Post by Coopervid » Tue May 13, 2025 12:15 pm
Hi Coopervid,
Revision: 1.14
Serial number: ...
PM sent.
#224 Post by Coopervid » Tue May 13, 2025 12:16 pm
Produzent: PIONEER
Revision: 1.10
Serienummer: ...
PM sent.
fitbrit
#225 Post by fitbrit » Mon Aug 04, 2025 8:26 pm
@coopervid
I just bought two of these drives from staples.
Hoping that you might be able to help me once I get them and post the info here.
Thanks very much for helping all of us in this thread!
