Segmentation fault when connecting to streaming server
siloportem
#1 Post by siloportem » Mon Dec 26, 2011 11:44 am
I am trying makemkv for the first time and I wanted to watch a Bluray over the streaming server.
But when I try to connect to the streaming server with mplayer, makemkv stops with a segmentation fault.
I am using makemkv 1.7.0 on Gentoo Linux 64 bit with gcc 4.6.2
Here is my debug log:
MakeMKV v1.7.0 linux(x64-release) started
Debug logging enabled, log will be saved as /home/dennis/MakeMKV_log.txt
Profile parsing error: default profile missing, using builtin default
DEBUG: Code 0 at a$S0YL}Jl[n9tNyXG&f"wI4:213130122
File 00001.mpls was added as title #0
Title #00500.mpls has length of 120 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00501.mpls has length of 120 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00503.mpls has length of 120 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00505.mpls has length of 120 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00011.mpls has length of 120 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00008.mpls has length of 124 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title 00009.mpls is equal to title 00001.mpls and was skipped
Title 00602.mpls is equal to title 00001.mpls and was skipped
Title #00001.m2ts has length of 23 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00004.m2ts has length of 64 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00005.m2ts has length of 60 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00006.m2ts has length of 276 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00007.m2ts has length of 60 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00008.m2ts has length of 60 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00009.m2ts has length of 10 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00010.m2ts has length of 60 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00011.m2ts has length of 60 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00012.m2ts has length of 60 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00013.m2ts has length of 60 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00014.m2ts has length of 490 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00015.m2ts has length of 94 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00016.m2ts has length of 353 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00017.m2ts has length of 120 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00018.m2ts has length of 37 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00019.m2ts has length of 130 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00020.m2ts has length of 84 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00021.m2ts has length of 72 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00022.m2ts has length of 77 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00023.m2ts has length of 116 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00024.m2ts has length of 67 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00025.m2ts has length of 82 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00026.m2ts has length of 77 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00027.m2ts has length of 148 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00028.m2ts has length of 114 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00029.m2ts has length of 113 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00030.m2ts has length of 17 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Streaming server started, web server address is http://192.168.0.81:51000 or http://localhost:51000
UPnP server enabled on address 192.168.0.81
DEBUG: Code 18359218 at U~Vn93`M,^FqUj,e~D:213134653
DBG ASSERT: R0h^k7Pf!K>g;=oS1>X=(}2zQnKzb' at Jo@1L+}NEY(UE|N|#/:213130559
[1]    4056 segmentation fault  makemkvcon stream disc:1 --minlength=4800 --debug
Re: Segmentation fault when connecting to streaming server
#2 Post by mike admin » Tue Dec 27, 2011 12:15 pm
siloportem
#3 Post by siloportem » Tue Dec 27, 2011 2:39 pm
I have sent you the core dump per email.
tangram
#4 Post by tangram » Mon Feb 27, 2012 8:11 am
Same problem here with 1.7.2 on Ubuntu 11.04.
It happen whenever I switch the language of the stream.
tangram
#5 Post by tangram » Sat Mar 03, 2012 3:31 pm
Since I disabled the rip- and region-lock on my drive (LG LG BE12LU38) the transfer speed has increase fom 9 MByte/s to 40 MByte/s! After this switching between the languages (soundtracks) of the disk works almost instantly with a local connetion. When using XBMC on a remote PC it is taking much longer, but it works now.
Don't know if the riplock and the crash is related, but for me this was a solution.
I used the following application to disable the riplock:
http://ala42.cdfreaks.com/MCSE/
