Pioneer BDR-UD03 UHD possibility
Wonsz
Re: Pioneer BDR-UD03 UHD possibility
Is this drive suitable for flashing? It's Verbatim (Pioneer inside).
OS device name: H:
Manufacturer: PIONEER
Product: BD-RW BDR-UD03
Revision: 1.14
Serial number:
Firmware date: 2020-06-15
Highest AACS version: 66
Drive platform: RS8511
Firmware version: 1.14
OS device name: H:
Revision: 1.14
Serial number:
PM sent.Wonsz wrote: Sat May 03, 2025 10:53 pm Is this drive suitable for flashing? It's Verbatim (Pioneer inside).
OS device name: H:
Revision: 1.14
Serial number:
jeramie
I am also interested as I have this drive as well. Thanks!
OS device name: G:
Revision: 1.14
Serial number:
Highest AACS version: 81
Unrestricted read speed: Yes-
PM sent.jeramie wrote: Mon May 05, 2025 2:48 pm I am also interested as I have this drive as well. Thanks!
Drive Information OS device name: G: Manufacturer: PIONEER Product: BD-RW BDR-UD03 Revision: 1.14 Serial number: Firmware date: 2020-06-15 Bus encryption flags: 1B Highest AACS version: 81 LibreDrive Information Status: Enabled Drive platform: RS8511 Firmware name: PIONEER BDR-US03 Firmware type: Original (unpatched) Firmware version: 1.14 DVD all regions: Yes BD raw data read: Yes BD raw metadata read: Yes Unrestricted read speed: Yes
V____
Hello, I'm facing an issue with my external Verbatim (Pioneer BD-RW BDR-UD03) device. Haven't been using it all that much, watched several BD movies, the last use was a few months ago, and now it just says "no disc inserted" (tried audio CDs, data DVDs, BDs, nothing can get read anymore).
Any chance to flash it or do whatever magic to get it to work once again? The unit was never dropped or in any way mechanically damaged that would prevent it from functioning properly. When the disc is inserted, the LED lits up for a second or two and then goes away.
Help will be appreciated, thanks.
Nero InfoTool 5.3.3.0
Drive : PIONEER BD-RW BDR-UD03
Type : Blu-ray Rewriter DL
Firmware Version : 1.10
Buffer Size : 4000 KB
Date : 17-04-18
Serial Number : ...
Vendor Specific : 17/04/18 PIONEER
Drive Letter : Z:\
Mechanism : Tray
Read Speed : n/a
Write Speed : n/a
Region Protection Control : RPC II
Region : none
Changes User : 5
Changes Vendor : 4
Flashing it won't magically make it start working again...V____ wrote: Mon May 05, 2025 8:50 pm Hello, I'm facing an issue with my external Verbatim (Pioneer BD-RW BDR-UD03) device. Haven't been using it all that much, watched several BD movies, the last use was a few months ago, and now it just says "no disc inserted" (tried audio CDs, data DVDs, BDs, nothing can get read anymore).
Nero InfoTool 5.3.3.0 Drive Information ------------------ Drive : PIONEER BD-RW BDR-UD03 Type : Blu-ray Rewriter DL Firmware Version : 1.10 Buffer Size : 4000 KB Date : 17-04-18 Serial Number : ... Vendor Specific : 17/04/18 PIONEER Drive Letter : Z:\ Location : 0:0 Mechanism : Tray Read Speed : n/a Write Speed : n/a Region Protection Control : RPC II Region : none Changes User : 5 Changes Vendor : 4
You could start by cleaning the lasers and see if that helps.
V____
Tried it, both with QTips and a cleaning CD, no improvement. Is there some kind of software available that could test whether the head can actually move by itself or how to figure out what is actually wrong with the device?
No, not that I know of.V____ wrote: Tue May 06, 2025 5:56 pm Tried it, both with QTips and a cleaning CD, no improvement. Is there some kind of software available that could test whether the head can actually move by itself or how to figure out what is actually wrong with the device?
The main reason for Verbatims going bad is the enclosure electronics. You could try to get it out and check with a mini SATA adapter on a desktop PC. If it works the next step could be buying a new enclosure for it or using a USB -> SATA adapter w/o a housing.V____ wrote: Mon May 05, 2025 8:50 pm Hello, I'm facing an issue with my external Verbatim (Pioneer BD-RW BDR-UD03) device. Haven't been using it all that much, watched several BD movies, the last use was a few months ago, and now it just says "no disc inserted" (tried audio CDs, data DVDs, BDs, nothing can get read anymore).
V____
Actually tried that as well. Here's how it went down - I purchased the external Verbatim (inside is of course Pioneer), used it several times as an external, and then figured it is easier if I install it in my notebook drive bay. Plug & play, worked without issues. I've since switched to a notebook that doesn't have an ODD bay anymore, purchased an external ICY BOX enclosure (USB-C), inserted the Pioneer DVD inside, and it is properly recognised as a device, however it just won't read any discs. I've tried to put the DVD unit back into its previous notebook, and nope, it didn't decide it likes it better there, still no joy with it.
I just want to figure out if there is anything that could help, before discarding a DVD unit that had maybe 20-30 hours of play time at most since purchased new, with several burned CD/DVDs, and that's all, don't see how the lasers could fail, since they haven't even been run-in properly.
I've figured out that the head actually moves (if I manually pull it back, once it attempts to read the placed media, it retracts back to its default starting position, close to the center).
Thanks for the efforts.
mkfantastico
Was wondering if it's possible to flash this to read UHD?
Revision: 1.14
Serial number:
Highest AACS version: 56
Revision: 1.14
Serial number:
PM sent.mkfantastico wrote: Wed May 07, 2025 8:03 pm Was wondering if it's possible to flash this to read UHD?
Revision: 1.14
Serial number:
abababab
I've got one of these fellas, some assistance and potentially firmware would be much appreciated
Revision: 1.14
Serial number: XXXXXXXXXXXX
TheTinderAccount
Hi y'all
Just bought a Verbatim USB3.1 Type-C Drive 43890
Does anyone know how to flash the drive so it can read UHD?
OS device name: H:
Revision: 1.14
Serial number: CIDL505149WL
Highest AACS version: 77
OS device name: H:
Revision: 1.14
bloom
If possible, I would like to flash my drive as well. Thanks in advance.
OS device name: /dev/sr0
Revision: 1.03
Serial number: ...
Firmware date: 2015-05-14
Drive platform: RS8510
Firmware version: 1.03/ID19
