300 UHD disc unable to rip.
DerGuteThor
Post by DerGuteThor »
everything work fine for 20 minutes an then suddenly reading speed drops to 0 and i get 2 error messages:
Fehler 'SCSI-Fehler - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' trat auf während des Auslesens von '/BDMV/STREAM/00004.m2ts' bei Offset '26033387520'
Fehler 'Betriebssystemfehler - STATUS_DEVICE_DATA_ERROR' trat auf während des Auslesens von '\Device\CdRom0' bei Offset '26009665536'
its in german.
anyone having the same issue?
Re: 300 UHD disc unable to rip.
same thing as always
clean the disc
replace the disc
clean the drive
get a pioneer
DerGuteThor
is a Pioneer Drive considered superior for 4k rips?
thanks for the answer!
Toker
Post by Toker »
DerGuteThor wrote: Tue May 06, 2025 5:19 pm is a Pioneer Drive considered superior for 4k rips?
What drive do you have now? I previously used an LG and it worked for 99% of my discs. It started having trouble a while back and in particular wouldn't read triple layer discs. My Pioneer has read everything.
DerGuteThor
i have a ASUS Bluray Drive
