No do not flash that drive it will brickdoodoofart wrote: ↑Thu May 01, 2025 9:54 amhi @ all and thanks for this great project.
a friend gave me an old external LG BP55EB40 he did not have any use for any longer. It doesn't read UHD discs so he bought another device.
I checked the specs and just wanted to make sure i don't screw it up.
i made a backup with SDFtool Flasher.
I unscrewed the external usb case and the drive itself says: MODEL: BU20NCode: Select all
Drive Information OS device name: D: Manufacturer: HL-DT-ST Product: BD-RE BP55EB40 Revision: 1.00 Serial number: MD[CENSORED] Firmware date: 2115-04-22 15:34 Bus encryption flags: 17 Highest AACS version: 72 LibreDrive Information Status: Enabled Drive platform: MT1959 Firmware type: Original (unpatched) Firmware version: 1.00 DVD all regions: Yes BD raw data read: Yes BD raw metadata read: Yes Unrestricted read speed: Yes
i would flash "HL-DT-ST-BD-RE_BP55EB40-NB50-1.03-NM00800-212005070924.bin" from this thread viewtopic.php?f=19&t=19113
using this commandis this correct or unnecessary risk?Code: Select all
.\makemkvcon64.exe f --all-yes -d D: rawflash -i C:\Users\flashgordon\Downloads\HL-DT-ST-BD-RE_BP55EB40-NB50-1.03-NM00800-212005070924.bin
much appreciated and have a good day
Ultimate UHD Drives Flashing Guide Updated 2025
BH16NS55 is in the list.disneyvader wrote: ↑Thu May 01, 2025 9:18 amWould these drives work after flashing? They don't appear in the list of proven drives but I am unable to find any of those here in the EU
LG BH16NS40
Hitachi-LG Data Storage BH16NS55
WH16NS40 is in the list. (WH/BH drives are the same thing)
HotJuicyBurgers
Bumping this again just in case,HotJuicyBurgers wrote: ↑Tue Apr 22, 2025 2:54 amHey all, been trying to flash my drive in linux, but my drive name is different than everyone elses. Anyone know what is up?
[root@8c4041fefc7c bin]# ./makemkvcon f -l
Found 1 drives(s)
00: dev_21:2, /dev/sr0, /dev/sr0
HL-DT-ST_BD-RE__WH14NS40_1.05_212005061444_KX1OC9E4345
I was asking about the format of my drive name being different (dev_21:2) because when I try to flash my drive the operation never finishes, and I'm guessing it isn't finding the drive? Not sure if anyone has run into this.
When I run the command it accepts it, but then nothing ever happens essentially, but also the drive isn't bricked or anything, still works fine and is visible in makemkv.
Hey all. So I bought this drive (LG WH16NS40) many years back, and until now I've only used it for regular BDs. Before I purchase my first UHD disc, I want to make sure I'll be able to rip it.
The drive was manufactured in April of 2017, has SVC NS50 on the label and meets all the other requirements specified in the first post. (See image below.)
I'm new to this process so apologies if my question is a stupid one. (I promise I searched various threads, but there are a lot of posts to sort through!) I know the OP says "All of these drives will need to be flashed to unlock UHD Reading/Ripping," but does this apply even if the drive is already on version 1.02? I just wanted to make sure flashing is still necessary before doing so (though it sounds like it's a good idea anyway if it fixes the sleep bug).
Thanks so much for your help, and to everyone who provided the tools and info to make this process simple for people like me!
Yes, that willl be able to rip UHD discs as is. No flashing required! Although you could flash it to WH16NS60 1.02-MK if you want to. It will then read a little faster and remove the sleep bug.KingMope wrote: ↑Sun May 04, 2025 5:10 amHey all. So I bought this drive (LG WH16NS40) many years back, and until now I've only used it for regular BDs. Before I purchase my first UHD disc, I want to make sure I'll be able to rip it.
The sleep bug is only an issue if you insert a UHD disc and leave it idle/unattended for a few minutes without doing anything. If you insert the UHD disc and start ripping straight away, you are fine. If it is left idle and unattended for a few minutes, just open/close the tray again and you are good to go again!
Heh, so I've been able to watch/rip UHD discs all this time without realizing it? I feel silly.MartyMcNuts wrote: ↑Mon May 05, 2025 12:04 amYes, that willl be able to rip UHD discs as is. No flashing required! Although you could flash it to WH16NS60 1.02-MK if you want to. It will then read a little faster and remove the sleep bug.
Hey guys, I have a lg wh14ns40 I've been using for years to rip/play uhd disks but as of recently I have noticed trouble with it reading some uhd disks. might be the head going bad over the years but figured I would try to flash its firmware but not entirely sure if my drive is a proper candidate or not?
SVC-NS50
firmware-v1.02
MD-8/17
SVC-NS50
firmware-v1.02
MD-8/17
I am struggling to flash my Asus with encrypted firmware on Xubuntu 24.04:
OS device name: /dev/sr0
Manufacturer: ASUS
Product: BW-16D1HT
Revision: 3.11
Serial number: ...
Firmware date: 2120-12-01 17:59
Bus encryption flags: 1F
I downloaded sdf.bin and the firmware package list from this post and ran the following command
makemkvcon f -d /dev/sr0 -f ~/Downloads/sdf.bin rawflash enc -i ~/Downloads/The\ all\ you\ need\ firmware\ pack/Asus\ 5.25\ BW-16D1HT/ASUS-BW-16D1HT-3.10-WM01601-211901041014.bin -t mtk1959
and received the following error:
No drive tool logic found in SDF.bin
Internal error 0x8d000000
I get this output regardless if I include '-t mtk1959' or not and also doesn't matter where I put that argument within the command. I also tried '-t mt1959' with the same results
Is it possible to flash this device from linux?
Manufacturer: ASUS
Product: BW-16D1HT
Revision: 3.11
Serial number: ...
Hey Guys,
iam new to saving blurays and got a new verbatim 43888 from amazon:
OS device name: F:
Product: BD-RE BU40N
Revision: 1.05
Serial number: ...
Highest AACS version: 36
I've read the Ultimate UHD Drive Falsing Guide 2025 and downloaded the firmware files but am unsure what are the correct files for enabling libredrive.
Thanks very much for your help
OS device name: F:
Revision: 1.05
Serial number: ...
Flash it to BU40N 1.03 MK. You can leave there and use it with MakeMKV/xReveal or you can flash it a second time, to BU40N 1.00 allowing you to use it with any good ripping software.2Close wrote: ↑Mon May 05, 2025 5:06 pmHey Guys,
OS device name: F:
Revision: 1.05
Serial number: ...
Thanks very much for your help![]()
Just picked up a BDR-212V from Amazon. If I can get it to work, I'll order another three to replace all four of my LGs.
Coopervid or Billycar11 could I get a PM with the information on how to flash this drive. The firmware is before December 2022 even though the drive was manufactured in 2024.
Actually I'm hopefully the Pioneers will be able to read some troubled discs that the LGs can't get through without errors. Thanks much.
OS device name: I:
Manufacturer: PIONEER
Product: BD-RW BDR-212V
Revision: 1.02
Serial number: DGDL027672WL
Firmware date: 2022-05-31
Bus encryption flags: 13
Highest AACS version: 81
Firmware version: ID06
Edit:
Should I be able to rip Blu-rays (not UHD) with an unpatched drive? It reads the title name but it can't decrypt the disc. Though Cyberlink PowerDVD is able to play the movie so the drive must be good.
OS device name: I:
Revision: 1.02
Edit:
Ist that the correct file?MartyMcNuts wrote: ↑Tue May 06, 2025 12:07 amFlash it to BU40N 1.03 MK. You can leave there and use it with MakeMKV/xReveal or you can flash it a second time, to BU40N 1.00 allowing you to use it with any good ripping software.2Close wrote: ↑Mon May 05, 2025 5:06 pmHey Guys,
OS device name: F:
Revision: 1.05
Serial number: ...
HL-DT-ST-BD-RE_BU40N-1.03-NM00000-211810241934.bin
from The all you need firmware pack?
Yes, try it.
I just got the same drive with most information the same, except "Highest AACS version" saying 81 in my case (and I'm using macOS, so OS device name corresponds to that). I also can't find the mentioned file HL-DT-ST-BD-RE_BU40N-1.03-NM00000-211810241934.bin in the current pack. What should I use? I'm sorry if this is supposed to be obvious.2Close wrote: ↑Mon May 05, 2025 5:06 pmHey Guys,
OS device name: F:
Revision: 1.05
Serial number: ...
