"Fatal error occurred" with upgrade to 1.7
romney
Post by romney »
I took the compulsory upgrade to 1.7.0 (free) today, and straightaway MakeMKV stopped working. It starts examining the disks (of a standard Buffy box set):
Title #0 was added (15 cells(s), 0:40:52)
Title #1 was added (15 cells(s), 0:40:51)
Title #2 was added (15 cells(s), 0:40:53)
Title #3 was added (15 cells(s), 0:40:53)
Title #4 was added (1 cells(s), 0:00:26)
Subtitle stream #4 is identical to stream #3 and was skipped
BUT THEN I get a popup error dialogue:
"Fatal error occurred, program will now exit."
I can't get any further and I have tried other disks that it has ripped before. I haven't changed the settings and I've never had a problem with MakeMKV before. Whats going on?
crowfax
Re: "Fatal error occurred" with upgrade to 1.7
Post by crowfax »
Can you try uninstalling and and deleting the ".MakeMKV" folder (check the settings in MakeMKV to see where it is on your machine). The reinstall the software and see if it fixes it.
mbryanr
Post by mbryanr »
Tried the above...thx, but it still didn't work, reverted back to 1.6.16 and ran fine.
XP Professional SP3
Did another install on another XP laptop with 1.7 - no problems.
mbryanr
Post by mbryanr »
Other reports of the same error. Debug log shows nothing except makemkv exiting.
Identical to these:
http://www.makemkv.com/forum2/viewtopic.php?f=7&t=4441
http://www.makemkv.com/forum2/viewtopic.php?f=7&t=4434
As I reported earlier, I've deleted the .makemkv folder, re-installed 1.7 with the same fatal error. Anything else I can try?
Post by mike admin »
Same questions for you as in other topic - Do you get a pop-up window about application crash for makemkvcon.exe ? If not, then if you open a task manager right after the fatal error, do you still see makemkvcon.exe (or makemkvcon64.exe ) running? Also, if you run "makemkvcon info disc:0" from command line, then what happens?
mbryanr
Post by mbryanr »
See the screeen shot immediately after the fatal error:
https://docs.google.com/open?id=0B4ntkn ... U1NDU1Y2Jk
makemkvcon is still running until I click on the "OK" popup
and makemkvcon info disc:0 screen shot:
https://docs.google.com/open?id=0B4ntkn ... JlNmJhMGJj
i12flytoday
Post by i12flytoday »
I get the same popup and task manager results as above. Very random though, no consistency on when it will happen or not.
mbryanr
Post by mbryanr »
Happens every time with my xp laptop.
Chetwood
Post by Chetwood »
Same here on Win 7 64 bit. My registered version locks up after "operation successfully completed" and all streams are listed. Now I'm back on 1.6.16 and the same Blurays (previously ripped with DVDfab) open flawlessly. Sucks big time for me cause I wanted to make use of conversion profiles.
yakuza965
Post by yakuza965 »
I experience exactly the same thing on my version installed on my Windows Home Server 2011. When I try to open the 1.7.1 update, I experience a very long delay of 2-3 minutes where the program does not appear, followed by the error "fatal error occurred, program will now exit" as other people have shown. The strange thing is, the GUI does then show up but with no drives or functionality.
I have used many prior versions with no issue, although I have since tried to roll-back to 1.7.0 and experience the same thing.
Happy to provide anything that can help this be fixed.
crowfax
Post by crowfax »
Try uninstalling and removing the .makemkv folder from your home directory, rebooting, then reinstalling.
You never know, something might have gotten messed up during the install.
yakuza965
Post by yakuza965 »
crowfax wrote:Try uninstalling and removing the .makemkv folder from your home directory, rebooting, then reinstalling.
I've tried this, I also tried searching and cleaning out all makemkv references in the registry after uninstalling, then rebooting and reinstalling. None seem to make it work.
Chetwood
Post by Chetwood »
1.7.1 works for me just fine.
yakuza965
Post by yakuza965 »
Chetwood wrote:1.7.1 works for me just fine.
Appreciate that it's working fine for most, and indeed it's working fine on my Mac running OSX, just won't seem to work on Windows and I'd quite like to figure out why.
mbryanr
Post by mbryanr »
Don't know what changed, but I downloaded and re-installed <for the 10th+ time>...and it works now.
Prior to that, this was the section of the windbg output where the program failed
ModLoad: 21d20000 21fe5000   C:\WINDOWS\system32\xpsp2res.dll
(edc.1098): Break instruction exception - code 80000003 (first chance)
eax=7ffd7000 ebx=00000001 ecx=00000002 edx=00000003 esi=00000004 edi=00000005
eip=7c90120e esp=2173ffcc ebp=2173fff4 iopl=0         nv up ei pl zr na pe nc
cs=001b  ss=0023  ds=0023  es=0023  fs=0038  gs=0000             efl=00000246
*** ERROR: Symbol file could not be found.  Defaulted to export symbols for C:\WINDOWS\system32\ntdll.dll -
ntdll!DbgBreakPoint:
7c90120e cc              int     3
Missing image name, possible paged-out or corrupt data.
