I've had ongoing issues with my BW-16D1HT since installing MakeMKV 1.15.2.
On many occaisons MakeMKV will spin up the drive and, after many minutes have passed, insist there is no disc in the drive.
I flashed to an MK firmware. Same issue.
I flash to an LG firmware. Same issue.
Under both firmwares if I revert to MakeMKV 1.15.1 discs are detected first time, everytime.
Asus BW-16D1HT 3.10 Firmware
Navvie
Re: Asus BW-16D1HT 3.10 Firmware
Registered user
Linux / Windows 10
Asus BW-16D1HT 3.10MK (disc exploded, taking out my second BW-16D1HT)
Asus BC-12D2HT 3.11MK
LG BH16NS40 flashed to WH16NS60 1.03
LG GGC-H20L 1.03
Pioneer BDR-205 GENE
Linux / Windows 10
LG GGC-H20L 1.03
Spencerpaul
Hi, I have an ASUS BW-16D1HT with 3.11 firmware and I’m unable to flash to 3.10MK or 3.02MK using the modified ASUS flasher or SDFtool (I get error #4 and 0xfff056103). Could someone please provide the Mtkflash tool or direct me to a working mirror? Thanks so much!
Make sure there's no disc in the drive! Only use SDFTool Flasher.Spencerpaul wrote: Tue May 06, 2025 1:06 am Hi, I have an ASUS BW-16D1HT with 3.11 firmware and I’m unable to flash to 3.10MK or 3.02MK using the modified ASUS flasher or SDFtool (I get error #4 and 0xfff056103). Could someone please provide the Mtkflash tool or direct me to a working mirror? Thanks so much!
As you have encrypted firmware on the drive, you must flash either BW-16D1HT 3.10-MK or WH16NS60 1.02-MK before any other firmware versions.
