But when I try to connect to the streaming server with mplayer, makemkv stops with a segmentation fault.
I am using makemkv 1.7.0 on Gentoo Linux 64 bit with gcc 4.6.2
Here is my debug log:
MakeMKV v1.7.0 linux(x64-release) started
Debug logging enabled, log will be saved as /home/dennis/MakeMKV_log.txt
Profile parsing error: default profile missing, using builtin default
DEBUG: Code 0 at a$S0YL}Jl[n9tNyXG&f"wI4:213130122
File 00001.mpls was added as title #0
Title #00500.mpls has length of 120 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00501.mpls has length of 120 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00503.mpls has length of 120 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00505.mpls has length of 120 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00011.mpls has length of 120 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00008.mpls has length of 124 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title 00009.mpls is equal to title 00001.mpls and was skipped
Title 00602.mpls is equal to title 00001.mpls and was skipped
Title #00001.m2ts has length of 23 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00004.m2ts has length of 64 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00005.m2ts has length of 60 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00006.m2ts has length of 276 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00007.m2ts has length of 60 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00008.m2ts has length of 60 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00009.m2ts has length of 10 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00010.m2ts has length of 60 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00011.m2ts has length of 60 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00012.m2ts has length of 60 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00013.m2ts has length of 60 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00014.m2ts has length of 490 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00015.m2ts has length of 94 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00016.m2ts has length of 353 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00017.m2ts has length of 120 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00018.m2ts has length of 37 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00019.m2ts has length of 130 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00020.m2ts has length of 84 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00021.m2ts has length of 72 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00022.m2ts has length of 77 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00023.m2ts has length of 116 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00024.m2ts has length of 67 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00025.m2ts has length of 82 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00026.m2ts has length of 77 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00027.m2ts has length of 148 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00028.m2ts has length of 114 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00029.m2ts has length of 113 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Title #00030.m2ts has length of 17 seconds which is less than minimum title length of 4800 seconds and was therefore skipped
Streaming server started, web server address is http://192.168.0.81:51000 or http://localhost:51000
UPnP server enabled on address 192.168.0.81
DEBUG: Code 18359218 at U~Vn93`M,^FqUj,e~D:213134653
DBG ASSERT: R0h^k7Pf!K>g;=oS1>X=(}2zQnKzb' at Jo@1L+}NEY(UE|N|#/:213130559
[1]    4056 segmentation fault  makemkvcon stream disc:1 --minlength=4800 --debug
