Fix libmakemkv1 tight versioned dependency on libavcodec due to call to private function
prahal
Post by prahal » Wed Mar 19, 2025 5:55 pm
I made this patch to import code from private libavcodec mpegaudiodecheader
avpriv_mpegaudio_decode_header in libmakemkv1 instead of calling this libavcodec private function.
https://salsa.debian.org/BenTheTechGuy/ ... 4d6e3fa3c0
This removes the tight dependency on minor version, especially in Debian deb packaging (though any non-broken packaging ought to have this tight dependency if a private function is called from a library if this package tooling was correct).
I mentioned this patch in viewtopic.php?p=168212&sid=ff3621ec6df4 ... bd#p168212 but did not get any feedback.
In Ben apt repository, this private call tight dependency prevents to upgrade libavcodec at each of their minor version upgrades.
Not that I find not upstream source repository to send a PR to, so I am opening this thread.
Re: Fix libmakemkv1 tight versioned dependency on libavcodec due to call to private function
Post by mike admin » Sat Apr 05, 2025 7:46 pm
This (avpriv dependency removal) will be fixed in the next version.
prahal
Post by prahal » Mon May 05, 2025 12:33 am
I see 1.18.1 from 8th of April 2025 still has the private call avpriv_mpegaudio_decode_header in ffm_mpa_decode_header,
so I guess you mean the next release after the release that you were going to ship (your message was from the 5th of April 20225).
Just to make it clear to readers of this thread that 1.18.1 still has this tight dependency constraint. (and avoid them having to check in the source code as I did, no need for duplicate work).
Thanks a lot for your work, I am eager to see Ben shipping makemkv in Debian repositories.
