Pioneer BDR-UD03 UHD possibility
Wonsz
Re: Pioneer BDR-UD03 UHD possibility
Post by Wonsz »
Is this drive suitable for flashing? It's Verbatim (Pioneer inside).
OS device name: H:
Manufacturer: PIONEER
Product: BD-RW BDR-UD03
Revision: 1.14
Serial number:
Firmware date: 2020-06-15
Highest AACS version: 66
Drive platform: RS8511
Firmware version: 1.14
Wonsz wrote: Sat May 03, 2025 10:53 pm Is this drive suitable for flashing? It's Verbatim (Pioneer inside).
OS device name: H:
Revision: 1.14
Serial number:
PM sent.
jeramie
Post by jeramie »
I am also interested as I have this drive as well. Thanks!
OS device name: G:
Revision: 1.14
Serial number:
Highest AACS version: 81
jeramie wrote: Mon May 05, 2025 2:48 pm I am also interested as I have this drive as well. Thanks!
OS device name: G:
Revision: 1.14
Serial number:
PM sent.
V____
Post by V____ »
Hello, I'm facing an issue with my external Verbatim (Pioneer BD-RW BDR-UD03) device. Haven't been using it all that much, watched several BD movies, the last use was a few months ago, and now it just says "no disc inserted" (tried audio CDs, data DVDs, BDs, nothing can get read anymore).
Any chance to flash it or do whatever magic to get it to work once again? The unit was never dropped or in any way mechanically damaged that would prevent it from functioning properly. When the disc is inserted, the LED lits up for a second or two and then goes away.
Help will be appreciated, thanks.
Nero InfoTool 5.3.3.0
Drive                      : PIONEER  BD-RW   BDR-UD03
Type                       : Blu-ray Rewriter DL
Firmware Version           : 1.10
Buffer Size                : 4000 KB
Date                       :  17-04-18
Serial Number              : ...
Vendor Specific            :   17/04/18  PIONEER
Drive Letter               : Z:\
Mechanism                  : Tray
Read Speed                 :  n/a
Write Speed                :  n/a
Region Protection Control  : RPC II
Region                     : none
Changes User               : 5
Changes Vendor             : 4
V____ wrote: Mon May 05, 2025 8:50 pm Hello, I'm facing an issue with my external Verbatim (Pioneer BD-RW BDR-UD03) device. Haven't been using it all that much, watched several BD movies, the last use was a few months ago, and now it just says "no disc inserted" (tried audio CDs, data DVDs, BDs, nothing can get read anymore).
Date                       :  17-04-18
Serial Number              : ...
Drive Letter               : Z:\
Mechanism                  : Tray
Read Speed                 :  n/a
Write Speed                :  n/a
Region                     : none
Changes User               : 5
Changes Vendor             : 4
Flashing it won't magically make it start working again...
You could start by cleaning the lasers and see if that helps.
V____
Post by V____ »
Tried it, both with QTips and a cleaning CD, no improvement. Is there some kind of software available that could test whether the head can actually move by itself or how to figure out what is actually wrong with the device?
V____ wrote: Tue May 06, 2025 5:56 pm Tried it, both with QTips and a cleaning CD, no improvement. Is there some kind of software available that could test whether the head can actually move by itself or how to figure out what is actually wrong with the device?
No, not that I know of.
Date                       :  17-04-18
Serial Number              : ...
Drive Letter               : Z:\
Mechanism                  : Tray
Read Speed                 :  n/a
Write Speed                :  n/a
Region                     : none
Changes User               : 5
Changes Vendor             : 4
The main reason for Verbatims going bad is the enclosure electronics. You could try to get it out and check with a mini SATA adapter on a desktop PC. If it works the next step could be buying a new enclosure for it or using a USB -> SATA adapter w/o a housing.
V____
Post by V____ »
Actually tried that as well. Here's how it went down - I purchased the external Verbatim (inside is of course Pioneer), used it several times as an external, and then figured it is easier if I install it in my notebook drive bay. Plug & play, worked without issues. I've since switched to a notebook that doesn't have an ODD bay anymore, purchased an external ICY BOX enclosure (USB-C), inserted the Pioneer DVD inside, and it is properly recognised as a device, however it just won't read any discs. I've tried to put the DVD unit back into its previous notebook, and nope, it didn't decide it likes it better there, still no joy with it.
I just want to figure out if there is anything that could help, before discarding a DVD unit that had maybe 20-30 hours of play time at most since purchased new, with several burned CD/DVDs, and that's all, don't see how the lasers could fail, since they haven't even been run-in properly.
I've figured out that the head actually moves (if I manually pull it back, once it attempts to read the placed media, it retracts back to its default starting position, close to the center).
Thanks for the efforts.
mkfantastico
Post by mkfantastico »
Was wondering if it's possible to flash this to read UHD?
Revision: 1.14
Serial number:
Highest AACS version: 56
mkfantastico wrote: Wed May 07, 2025 8:03 pm Was wondering if it's possible to flash this to read UHD?
Revision: 1.14
Serial number:
PM sent.
abababab
Post by abababab »
I've got one of these fellas, some assistance and potentially firmware would be much appreciated :)
Revision: 1.14
Serial number: XXXXXXXXXXXX
TheTinderAccount
Post by TheTinderAccount »
Hi y'all
Just bought a Verbatim USB3.1 Type-C Drive 43890
Does anyone know how to flash the drive so it can read UHD?
OS device name: H:
Revision: 1.14
Serial number: CIDL505149WL
Highest AACS version: 77
bloom
Post by bloom »
If possible, I would like to flash my drive as well. Thanks in advance.
OS device name: /dev/sr0
Revision: 1.03
Serial number: ...
Firmware date: 2015-05-14
Drive platform: RS8510
Firmware version: 1.03/ID19
