Hi All,
After plenty of searching I haven't been able to find help for my problem so I decided to make an account and post about it. I'm trying to digitize all my old HD-DVDs, and I'm having some trouble. I've got 3 Xbox360 HD-DVD drives, and the same results with each one. I've successfully ripped Transformers, but I keep striking out with the rest. MakeMKV reads the discs, finishes decrypting and then hangs on processing files. It gets to different spots before it hangs, but it still hangs. Here is the output for End Of Days:
MakeMKV v1.10.2 darwin(x86-release) started
Optical drive "DVD+R-DL MATSHITA DVD-R UJ-8A8 HB14d" opened in OS access mode.
Optical drive "BD-ROM TOSHIBA DVD/HD X807616 MC08" opened in OS access mode.
It's highly recommended to install DASPI kernel extension to improve performance.
The new version 1.10.4 is available for download at /download/
Title #BLACK.EVO has length of 60 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #UNILOGO.EVO has length of 29 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #SSHOW.EVO has length of 70 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #TRAILER.EVO has length of 74 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #TRACKSPOT.EVO has length of 32 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #TRACKLIST.EVO has length of 25 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #SEQ_ALBINO.EVO has length of 30 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #SEQ_CHURCHFIRE.EVO has length of 33 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #SEQ_CREATURE.EVO has length of 48 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #SEQ_HUMANWORMS.EVO has length of 21 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #SEQ_JERICHO.EVO has length of 18 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #SEQ_LATONY.EVO has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #SEQ_SATAN.EVO has length of 117 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #DELOGO.EVO has length of 13 seconds which is less than minimum title length of 120 seconds and was therefore skipped
I'm currently running macOS Sierra 10.12.1
HD-DVD Help
ricer23
Re: HD-DVD Help
As a follow up, I just ripped The War without issue. Could it be an AACS issue?
Re: HD-DVD Help
Given that nothing has changed on the HD DVD front since it was discontinued, AACS should not be the issue. But someone who knows more about it than me would have to comment further.
ricer23
Re: HD-DVD Help
Makes total sense. I'm ripping King Kong right now without issues too. So this is really confusing for me.Woodstock wrote:Given that nothing has changed on the HD DVD front since it was discontinued, AACS should not be the issue. But someone who knows more about it than me would have to comment further.
ricer23
Re: HD-DVD Help
An update for everyone. I've also got Streets of Fire ripping fine. It seems to work on HD-DVDs that don't have any special features. Anything with even a few special features and it just hangs on processing titles.
ricer23
Re: HD-DVD Help
FIXED! I switch to version 1.9.9 and it works perfectly now!
turnkit
Re: HD-DVD Help
I hope this gets fixed. I also would like to rip my HD-DVDs.
Re: HD-DVD Help
Question that Mike will need answered, I think - at which version did it STOP working?
Developers have tools that tell them what changed at each version change, so knowing what update broke HD DVD ripping will narrow what needs to be "un-changed" to make it right again.
ricer23
Re: HD-DVD Help
The earliest version that I tried that it didn't work on was 1.10.2.
mister_eff
Re: HD-DVD Help
ricer23
Thank you so much for posting your experiences! I was having similar trouble ripping HD-DVDs with my Xbox 360 drive. I'm on Windows 10 but I was running into the same issue and it seems to have fixed itself after I reverted to MakeMKV 1.9.9. I successfully ripped Serenity just now.
This is the log I get with 1.9.9:
When I had 1.10.4, it would get stuck at the #FRUITY.EVO line. I wouldn't be able to progress to picking the streams and doing the actual ripping. But 1.9.9 seems to work perfectly!MakeMKV v1.9.9 win(x64-release) started
Profile parsing error: multiple default profiles found, rename your custom profile
Title #MAININTRO.EVO has length of 64 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #MAINLOOP.EVO has length of 59 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #DELSCENE1.EVO has length of 29 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #DELSCENE2.EVO has length of 74 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #DELSCENE6.EVO has length of 95 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #DELSCENE7.EVO has length of 21 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #DELSCENE9.EVO has length of 75 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #FRUITY.EVO has length of 98 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Saving 1 titles into directory ...
1 titles saved
MainFrame
Re: HD-DVD Help
I am down to one working HD-DVD player, so it is high time I got around to preserving content from my original HD-DVDs.
Is it still possible to obtain V1.9.9 for Windows or Mac OSx?
Will it work as Beta or do I need to buy a license for this activity?
MetalDave
Re: HD-DVD Help
Speaking from recent experience, the latest version of MakeMKV does just fine ripping most HD-DVD titles. You may need to make sure you have the appropriate keys for a given title. I touched on this in another post.MainFrame wrote: Fri Apr 03, 2020 5:50 pm I am down to one working HD-DVD player, so it is high time I got around to preserving content from my original HD-DVDs.
Good luck!
Support MakeMKV - Buy a license!
(Seriously, you use this thing enough; A lifetime license is well worth it.)
Thank you to all of my fellow supporters!
Heis3nberg88
Re: HD-DVD Help
Hey guys,
it's amazing to see, that there are still some folks in 2020 who share their love for HD DVDs. I'm trying to safe my HD DVD collection as well on a physical medium, but I'm not a native english speaker and it's really hard to get into this whole key stuff and maybe I'm not the only one who is struggling. So perhaps, there is a glory samaritan, who can post his key list as a download, with a short description to help complete blockheads like me, to get their mkv's done. This would be sooo awesome - thank you already!
Best regards,
Heis3nberg88
Best regards,
Heis3nberg88
kawal
Re: HD-DVD Help
I tired using the latest version for HDVD but it did not work. I just used version 1.10.10 and it worked perfectly without issues. You will need to search for older versions for the older format. Not sure when the support ended and which version works best for HD DVD but 1.10.10 works for sure.
Also tested 1.12.3 and seems to rip faster than 1.10.10.
1.14.7. seems broken for HDDVD
Based on this I would use 1.12.3
clarkdevan
Re: HD-DVD Help
Im using my Xbox 360 HD DVD drive on win 11 pc. Some hddvds are ripping fine to mkv. But others only the special features are being recognized at the start. Is there a reason makemkv is not recognizing the main feature on some discs?
Any help appreciated.
I'm running makemkv v1.17.9
