Re: SDFtool Flasher
#1306 Post by MartyMcNuts » Sat May 03, 2025 6:17 am
KAIJUKACZ25 wrote: Sat May 03, 2025 4:46 am Ok..
Well, I thought I was doing all you said to do, correctly:
I put in the 4k Godz movie in 1st, and then opened MKV, hit the "BACKUP" tab, and 1/2 way through, I get the "BWoD" 'Blue Windows of Death'!!
What am I doing wrong>? I have, now, 1.8 TB on the "J:" drive. Do I need more space?
Really 'confused-as-all-Hell'
Did MakeMKV stop ripping half way through? If so, what did the log window at the bottom say? Copy and paste the log comments here.
What is J drive? Is that an external HDD or SSD? If so, make sure it if formatted as NTFS.
KAIJUKACZ25
Re: SDFtool Flasher
#1307 Post by KAIJUKACZ25 » Sat May 03, 2025 1:43 pm
Yes, that is what it seemed to do.. Am I supposed to "Back-Up" 1st, before hitting the "MKV Folder" tab?
"J:" is my 2TB drive that I will be using to set up the MKV Folder, needed for the MKV process.
MKV BackUp info.jpg (152.56 KiB) Viewed 17069 times
KAIJUKACZ25
Re: SDFtool Flasher
#1308 Post by KAIJUKACZ25 » Sat May 03, 2025 1:52 pm
I have to be quick to "Catch" anything, as I get the BSoD when it says it is copying files, 1/2 way thru..
KAIJUKACZ25
Re: SDFtool Flasher
#1309 Post by KAIJUKACZ25 » Sat May 03, 2025 1:56 pm
GODz drive info.jpg (42.82 KiB) Viewed 17064 times
KAIJUKACZ25
Re: SDFtool Flasher
#1310 Post by KAIJUKACZ25 » Sat May 03, 2025 2:20 pm
I had to "Capture" this, and within seconds (saying it is copying, and after it Decrypts..) I get the BSoD, and the computer restarts. On the full screen, if You can't see, it says Elapsed 10sec. and on the bottom bar, 22sec
MKV Godz Back Up bef BSoD Info1.jpg (52.21 KiB) Viewed 17058 times
MKV Godz Back Up bef BSoD Info.jpg (225.36 KiB) Viewed 17058 times
KAIJUKACZ25
Re: SDFtool Flasher
#1311 Post by KAIJUKACZ25 » Sat May 03, 2025 4:52 pm
I noticed that some peeps were using some type of a FIRMWARE Change of some sorts, could that be something I need>?
KAIJUKACZ25
Re: SDFtool Flasher
#1312 Post by KAIJUKACZ25 » Sat May 03, 2025 8:40 pm
I killed All that is on my "J:" drive, and looks to already be formatted as NTFC (would I still need to Format?), so What/Why am I Still getting the BSOD this time, when I opened up MKV, it completed the Decrypt/Copying, and as soon as I tagged the MakeMKV button, screen went all 'KaBLUEy' on me!?
H E L P > >
J drive is NTFC.jpg (652.58 KiB) Viewed 17014 times
KAIJUKACZ25
Re: SDFtool Flasher
#1313 Post by KAIJUKACZ25 » Sat May 03, 2025 8:47 pm
Do I Still Need the Latest JAVA installed? To aid in any firmware updates?
I also read somewhere that I might need to install the "64-bit with Fall Creators Update 2017 Oct. update" on my PC, which I have, is the Win 10.5 (enterprise ver.) I have no idea, if that should even be used..>>
Would it be helpful to give you a 'SPECCY' readout of my Computer set-up?? ..just fishin' here..
baseddende
Re: SDFtool Flasher
#1314 Post by baseddende » Sat May 03, 2025 11:15 pm
dcoke22 wrote: Sat May 03, 2025 2:01 am
The Ultimate UHD Drives Flashing Guide recommends WH14NS40 on any Firmware directly to > WH16NS60 1.02MK
After you flash your drive to WH16NS60 1.02MK does the LibreDrive Information section on MakeMKV's first screen say the status is Enabled?
Turns out that the comment that I saw right after I left my comment said to another person to enable internet access on MakeMKV and that was the solution.
jwelker9
Re: SDFtool Flasher
#1315 Post by jwelker9 » Wed May 07, 2025 10:37 pm
jwelker9 wrote: Sat May 03, 2025 5:23 am Hey all! So do we have any list somewhere of dvd players out there on Amazon that would rip 4k movies? I'm seeing a few listed, but people mentioning that recent updates have removed the capability. I'm still relatively new to this game so anything that is "plug and play" would be great for me. Thanks all!
Nvm, I missed drive names are all listed at the beginning.... thanks.
KAIJUKACZ25
Re: SDFtool Flasher
#1316 Post by KAIJUKACZ25 » Thu May 08, 2025 1:17 am
I was in Hot-Persuit" of Info from MartyMcNuts, but, I have not read from him in a week, figuirin' he 'Had 'bout jus' Enuff of me',
so I ask this Illustrious Group of Brazen Bros to, "Up'n Please.. to Help out another, not like your Other, but like a brother, who needs serious HeLp", ASAP>>
ask Away & I'll Tell ALL! I only have a few more Days left on my 30 days of "MAKEMKV" access, so any Help, would.. HELP.. ASAP!?! Even if I must Return my PIONEER PIODATA External UHD BD Drive
MPN: PIOEXT3UHD, that I had bought 3+weeks ago (Time is a Tickin' on this to be Returned, if need be!) So.. I ask, for some HELP.. Please>>
Thank You {In Advance..}
KACZ
HK_Rickyeva
Re: SDFtool Flasher
#1317 Post by HK_Rickyeva » Thu May 08, 2025 1:51 am
KAIJUKACZ25 wrote: Thu May 08, 2025 1:17 am I was in Hot-Persuit" of Info from MartyMcNuts, but, I have not read from him in a week, figuirin' he 'Had 'bout jus' Enuff of me',
KACZ
what your problem?? can't rip by makemkv ??? or your drive is not support?? what is your windows os version ?? what your computer spec??
need more information..
Re: SDFtool Flasher
#1318 Post by MartyMcNuts » Thu May 08, 2025 3:55 am
KACZ
Bookmark this page: viewtopic.php?t=1053
You can get the latest free beta key from there everytime it expires. FYI, there is usually around a week between beta key expiry and the new beta key being added.
From all of your jumbled posts, I cannot make out what your issue is. It sounds more like system issues, not drive/MakeMKV issues.
Let's just start from scratch. Can you please copy/paste again, the text from the MakeMKV drive info and LibreDrive Info sections. Also tell us what type of drive "J" is and how it is connected to your PC.
KRIS_DETH
Re: SDFtool Flasher
#1319 Post by KRIS_DETH » Fri May 09, 2025 9:49 am
Hi all,
Hoping that I can pick someones brain as I've just purchased an LG WH14NS40 - checked on MakeMKV that it's MT1939 which it is, but when using the tool, it states that it isn't a MT1939 platform, see screenshot below, any ideas on the best way to get around this to get the correct firmware on it?
Drive Info.png (445.21 KiB) Viewed 15796 times
Any help will be greatly helpful!
Re: SDFtool Flasher
#1320 Post by dcoke22 » Fri May 09, 2025 11:51 am
KRIS_DETH wrote: Fri May 09, 2025 9:49 am Hi all,
If you look at the Ultimate UHD Drives Flashing Guide you'll notice right at the top is says your drive platform needs to be MT1959. SDFtool Flasher isn't flashing your drive because it is NOT the MT1959 platform; it is saving your from yourself. If you do flash your drive, you'll brick it and it'll be unusable.
