MakeMkv and Camcorder HD video
gchaimovitz
#1 Post by gchaimovitz » Sat Oct 24, 2009 1:25 am
I'm trying to figure out why MakeMKV is giving me an error when i try and convert the video from my camcorder. I was trying to find an easy way to grab the video, convert it to MKV (to utilize chapters) and play on my WDTV. When I backup from the SD card it creates a folder with a BD movie structure. I open the index.bdmv and it shows me all the files/chapters but when i hit create is says x files saved, x failed.
Any ideas please as this would work great for anyone with an HD camcorder (avchd, i'm currently using a Panasonic SD9).
Thanks.
gchaimovitz
Re: MakeMkv and Camcorder HD video
#2 Post by gchaimovitz » Tue Oct 27, 2009 12:09 am
Is there nobody out there who has the same issues? Am I missing something?
Taddeusz
#3 Post by Taddeusz » Tue Oct 27, 2009 11:22 am
Use tsmuxer GUI to demux the video and audio and then use mkvmerge to turn it into an mkv. Although doing it this way you'll lose the framerate. It will need to be specified when dropping it into mkvmerge.
gchaimovitz
#4 Post by gchaimovitz » Wed Oct 28, 2009 11:42 pm
Thanks, i was just hoping for the 1 step solution. I'd still like to find out what's going on with makemkv. I was using Clown_BD before to demux but when I use mkvmerge my audio/video is out of sync and zoom player or media player plays it in what looks like slo-mo, unless that's just 'cuz of the computer speed.
#5 Post by mike admin » Mon Nov 02, 2009 7:25 am
gchaimovitz wrote:I'm trying to figure out why MakeMKV is giving me an error when i try and convert the video from my camcorder. I was trying to find an easy way to grab the video, convert it to MKV (to utilize chapters) and play on my WDTV. When I backup from the SD card it creates a folder with a BD movie structure. I open the index.bdmv and it shows me all the files/chapters but when i hit create is says x files saved, x failed.
Thanks.
can you please enable "log debug messages" in preferences, reatart the app, try to open it again and post the log here?
gchaimovitz
#6 Post by gchaimovitz » Tue Nov 03, 2009 1:02 am
Here's the log:
MakeMKV v1.4.8 beta win(x86-release) started
Debug logging enabled, log will be saved as C:\Documents and Settings\Owner/MakeMKV_log.txt
Opening files on harddrive at C:/Documents and Settings/Owner/My Documents/PanasonicHD/HDWRITER/061708_1/PRIVATE/AVCHDL/
AACS directory not present, assuming unencrypted disc
File 00000.mpls was added as title #0
File 00001.mpls was added as title #1
File 00002.mpls was added as title #2
File 00003.mpls was added as title #3
File 00005.mpls was added as title #4
Title #00024.m2ts has length of 28 seconds which is less than minimum title length of 60 seconds and was therefore skipped
Operation sucessfully completed
Saving 5 titles into directory C:/Temp
FAILURE: Code 49 at 1fXrukp|B?%VDS)|Cv5:213133365
FAILURE: Code 0 at 1fXrukp|B?%VDS)|Cv5:121261888
FAILURE: Code 0 at 1fXrukp|B?%VDS)|Cv5:29393838
FAILURE: Code 0 at &]vQ?j]):Kn4LyoN5S0Cl:121264326
FAILURE: Code 0 at -)&6pavBKTTxFE/1S{I:121261980
FAILURE: Code 0 at -)&6pavBKTTxFE/1S{I:213131502
Failed to save title 0 to file C:/Temp/title00.mkv
Failed to save title 1 to file C:/Temp/title01.mkv
Failed to save title 2 to file C:/Temp/title02.mkv
Failed to save title 3 to file C:/Temp/title03.mkv
Failed to save title 4 to file C:/Temp/title04.mkv
0 titles saved, 5 failed
Thank you... i so hope I can make this work!
#7 Post by mike admin » Mon Nov 16, 2009 7:51 am
Thank you for sending all requested information. This error will be corrected in 1.4.9
