BDR 212V UHD Guide
Re: BDR 212V UHD Guide
#106 Post by Coopervid » Mon Apr 21, 2025 10:38 am
Rudyard wrote: Sun Apr 20, 2025 11:01 pm Got another BDR-212DBK. MakeMKV shows the exact same info now as it showed with the previous unit, same firmware etc, so I just flashed the same files I already had, since they had been successfully flashed on the first unit. And this time, according to the flashing program, everything went OK too. But the unit won't read any BD disc, neither regular not UHD discs. It reads DVD, though.
I've flashed it again just in case, but to no avail. Maybe this is a faulty unit. I should have checked if it read BD discs before flashing, like I did with the previous unit... I'll probably need to return it. Is there any way I can flash the original firmware back?
Product: BD-RW BDR-212D
Revision: 1.02
Firmware date: 2022-03-16
Thanks in advance.
PM sent.
Rudyard
#107 Post by Rudyard » Mon Apr 21, 2025 11:12 am
Thank you! Next time I'll be more cautious
jtuts
#108 Post by jtuts » Fri May 02, 2025 12:02 am
I should be getting this drive tomorrow and just wanted to get some clarification. From what I can tell, we are not able to flash this particular drive ourselves and the instructions are only available through PM. Is this correct?
If not, can someone please point me to the correct files/instructions? I would like to start understanding the process in preparation for flashing the drive.
#109 Post by Coopervid » Fri May 02, 2025 9:02 am
jtuts wrote: Fri May 02, 2025 12:02 am Hello,
Post your Makemkv info when you receive it. Please try CDs, DVDs and BDs when it arrives. Sometimes people receive defective returned drives.
jtuts
#110 Post by jtuts » Fri May 02, 2025 3:37 pm
Coopervid wrote: Fri May 02, 2025 9:02 am
Okay, will do. Thanks again!
jtuts
#111 Post by jtuts » Sat May 03, 2025 12:50 am
@Coopervid
Okay, finally got this setup, here is info you requested:
BR - good
CD - good
DVD - good
UHD - no disc inserted (which I assume is expected)
Screenshot 2025-05-02 174620.png (11.53 KiB) Viewed 17178 times
Edit: I also am using the Vantec NexStar DX2 enclosure, if that matters at all.
#112 Post by Coopervid » Sat May 03, 2025 10:06 am
jtuts wrote: Sat May 03, 2025 12:50 am @Coopervid
BR - good
CD - good
DVD - good
PM sent. Important when using an enclosure for flashing. Remove BOTH power and USB afterwards.
valentine
#113 Post by valentine » Mon May 05, 2025 10:01 pm
Hey Coopervid, could I perhaps get some help cross-flashing my BDR-212DBK? Here is the makemkv info:
OS device name: /dev/rdisk4
Manufacturer: PIONEER
Revision: 1.02
Serial number:
Bus encryption flags: 13
Highest AACS version: 68
Drive platform: RS8F00
Firmware version: 1.02/ID61
#114 Post by Coopervid » Tue May 06, 2025 9:32 am
valentine wrote: Mon May 05, 2025 10:01 pm Hey Coopervid, could I perhaps get some help cross-flashing my BDR-212DBK? Here is the makemkv info:
Revision: 1.02
Serial number:
PM sent.
Wolf2142
#115 Post by Wolf2142 » Tue May 06, 2025 9:28 pm
Hey, sorry been a long time since I used any forums and tried to post a topic (pending?), but maybe this is also a correct place?
I have the below drive, and from reading the forums I need to flash it to use it for UHD, can anyone help me out with the process via PM? I have never flashed a drive before and don't want use the wrong firmware or tool et al. and end up bricking the thing. Thank you in advance!
OS device name: XXXXX
Revision: 1.02
Serial number: XXXXXXXXXXX
Highest AACS version: 81
#116 Post by Coopervid » Wed May 07, 2025 9:50 am
Wolf2142 wrote: Tue May 06, 2025 9:28 pm Hey, sorry been a long time since I used any forums and tried to post a topic (pending?), but maybe this is also a correct place?
Revision: 1.02
PM sent.
briank
#117 Post by briank » Thu May 08, 2025 11:09 pm
Hi, could I please get the instructions for flashing this drive? Thank you!
OS device name: XX
Revision: 1.00
Serial number: XXXXXXXXXXXX
Firmware date: 2019-01-10
Highest AACS version: 77
Firmware version: 1.00/ID61
geraldog
#118 Post by geraldog » Fri May 09, 2025 11:14 pm
OS device name: /dev/sr0
Revision: 1.00
Serial number: ...
Hi Coopervid, could I get instructions and the firmware file for crossflashing the above 212dbk?
hud55duh
#119 Post by hud55duh » Mon May 12, 2025 5:22 am
Greetings been using MKV years and finally purchased my first UHD and yes didn't work. :) Would be great to get instruction on how to flash this drive. Is this windows only solution. Thank you in advance.
Drive information:
Product: BD-RW BDR-212V
Revision: 1.00
Firmware date: 2020-08-07
Firmware version: 1.00/ID06
AbyssalReClass
#120 Post by AbyssalReClass » Mon May 12, 2025 5:20 pm
Hello all, I've got a Pioneer BDR-212DBK that I picked up off of Amazon recently. It works great, except that it won't rip UHD out of the box. Is it possible to flash this from a Linux PC?
Here is my MakeMKV info:
Current profile: DVD-ROM
Revision: 1.02
Highest AACS version: 65
