Verbatim 43890 External Slimline Mobile USB 3.2 Blu-ray Writer UHD Problem
Sagenumwoben3
Re: Verbatim 43890 External Slimline Mobile USB 3.2 Blu-ray Writer UHD Problem
Hi Coopervid,
Would you also help me with the firmware? Many thanks in advance.
Manufacturer: PIONEER
Product: BD-RW BDR-UD03
Revision: 1.14
Serial number: ...
Firmware date: 2020-06-15
Highest AACS version: 81
Drive platform: RS8511
Firmware version: 1.14
Revision: 1.14
Serial number: ...
PM sent.Sagenumwoben3 wrote: Sat Apr 05, 2025 11:36 pm Hi Coopervid,
Revision: 1.14
Serial number: ...
Lancery
Coopervid, any chance I could get your help on this too? Thanks in advance!Lancery wrote: Wed Apr 02, 2025 6:57 am I am in the same boat. Is it possible for this drive to be able to support UHD? Can someone please help? TIA.
Drive Information OS device name: F: Current profile: DVD-ROM Manufacturer: PIONEER Product: BD-RW BDR-UD03 Revision: 1.14 Serial number: ... Firmware date: 2020-06-15 Bus encryption flags: 1B Highest AACS version: 12 LibreDrive Information Status: Enabled Drive platform: RS8511 Firmware name: PIONEER BDR-US03 Firmware type: Original (unpatched) Firmware version: 1.14 DVD all regions: Yes BD raw data read: Yes BD raw metadata read: Yes Unrestricted read speed: Yes
IamHerk
Hi Coopervid,
Thank you for helping us with our 43890 drives. Can I get your help on the firmware as well. Here's my drive info...
IamHerk
OS device name: F:
Revision: 1.14
Serial number: ...
IamHerk
OS device name: F:
Revision: 1.14
Serial number: ...
PM sent.IamHerk wrote: Thu Apr 10, 2025 3:52 pm Hi Coopervid,
IamHerk
OS device name: F:
Revision: 1.14
Serial number: ...
chris996
I'm using Verbatim UHD Blu-ray Writer. I have original (unpatched) version.
With this writer I copied the entire movie to my hard disk. Title: GLADIATOR 2000.
So the product is definitely worth recommending.
jacknw
Hi Coopervid,
Can you help share the firmware with me as well? Would really appreciate your help on that.
OS device name: F:
Revision: 1.14
Serial number: ...
OS device name: F:
Revision: 1.14
Serial number: ...
IamHerk
Thank you very much, the flash worked perfectly.Coopervid wrote: Fri Apr 11, 2025 4:08 pmPM sent.IamHerk wrote: Thu Apr 10, 2025 3:52 pm Hi Coopervid,
IamHerk
OS device name: F:
Revision: 1.14
Serial number: ...
IamHerk
bobburger
I'm also struggling with this on my 43890 Blu-ray writer. Any help appreciated!
OS device name: G:
Product: BD-RW BDR-UD04
Revision: 1.14
Serial number: DDDL526178WL
Drive platform: RS8A10
OS device name: G:
Revision: 1.14
Your drive is UHD enabled. However, these Verbatim enclosures are power hungry. Connect to USB3 or use a powered USB hub.bobburger wrote: Wed Apr 30, 2025 6:55 pm I'm also struggling with this on my 43890 Blu-ray writer. Any help appreciated!
OS device name: G:
Revision: 1.14
bobburger
Thanks for the quick reply. I have it now plugged into a USB3 with the dedicated power cable attached as well but it's still failing to read the disc. When inserted it starts to spin, with disc information showing "Disc is being loaded" but eventually gives me the same output as before.Coopervid wrote: Wed Apr 30, 2025 7:58 pmYour drive is UHD enabled. However, these Verbatim enclosures are power hungry. Connect to USB3 or use a powered USB hub.bobburger wrote: Wed Apr 30, 2025 6:55 pm I'm also struggling with this on my 43890 Blu-ray writer. Any help appreciated!
OS device name: G:
Revision: 1.14
Wash the disc even if it is brand new. Try again. Clean your laser lens with a CD cleaning disc.bobburger wrote: Wed Apr 30, 2025 8:34 pmThanks for the quick reply. I have it now plugged into a USB3 with the dedicated power cable attached as well but it's still failing to read the disc. When inserted it starts to spin, with disc information showing "Disc is being loaded" but eventually gives me the same output as before.Coopervid wrote: Wed Apr 30, 2025 7:58 pmYour drive is UHD enabled. However, these Verbatim enclosures are power hungry. Connect to USB3 or use a powered USB hub.bobburger wrote: Wed Apr 30, 2025 6:55 pm I'm also struggling with this on my 43890 Blu-ray writer. Any help appreciated!
OS device name: G:
Revision: 1.14
always let your os see the disc first then open makemkv do not have it opened first this sometimes causes conflictsbobburger wrote: Wed Apr 30, 2025 8:34 pm
jinx100
I have a couple Verbatim 43890 drives and they came with external power bricks. Have you tried using this external power source? I use that and it runs fine with single USB 2.0 connection.
Like Coopervid says, clean the disc. I've had new discs come with an oily film. Sometimes the disc is just defective, too.
babywinchester
Hey Coopervid
I have the same drive as well and need your help in reading UHD
please can you help me with the same would be obliged really
