Post by SamuriHL »
RESET_9999 wrote:
Thu May 01, 2025 4:38 pm
I don't remember how it was on the C8, but on the C2, I definitely never noticed anything like this. I’ll check again once it’s set up in my bedroom.
On my end, this only happens in dark scenes, and the 10% grayscale pattern looks terrible in Dolby Vision. At 20% and above, it's fine.
Thankfully, it’s much less noticeable in actual content.
At least now the DV black clipping is the same as the C2 for cmv4.0 and cmv2.9 is greatly improved. No way I could see 69-70 with cmv2.9 10 000nits and 4000nits MDL on the C2
As you know this'll likely improve as you put some more hours on it. Once you hit 100 hours and calibrate it maybe most of this goes away with any luck.
SamuriHL wrote:
Thu May 01, 2025 5:28 pm
I'm curious how the black crush is on your G2? Is it like my C2 crushed in cmv2.9 and way worse with 4000/10000 MDL ?
Is it perfect in cmv4.0?
Post by SamuriHL »
RESET_9999 wrote:
Thu May 01, 2025 7:35 pm
It's not perfect, no but it's not bad. I haven't checked it in a year. It's actually on my todo list. The last time I calibrated it I didn't do it the normal way as I was having issues with a new laptop at the time and had to use software I don't normally use. It came out decent so I left it. I need to redo it when I have time. I can throw spears and munsil in this weekend which as I said I need to do anyway. But I've not had any real issues after calibration. It is definitely worse in cmv2.9, though.
daffie
Post by daffie »
@RESET
You got that picture of the greyscale 10%?
LG OLED65G1RLA / Samsung HW-Q990D / Sony UBP-X800M2 / Ugoos AM6B+ (CE with CPM Build)
daffie
Post by daffie »
deadchip12 wrote:
Thu May 01, 2025 4:04 pm
I saw falling diagonal lines on my c8 and c9 oled too a long time ago. Not sure if it is the same kind as the ones on the g5. Could you check your c2 again if you see those lines?
Users and reviewers reported say they saw diagonal lines even in bright scenes since the g4. There's a reddit thread about the issue here: https://www.reddit.com/r/LGOLED/s/lLTwRgQtyw
And also there's a thread about another issue. You may want to check for it on the g5: https://www.avsforum.com/threads/lg-g4- ... 65/page-12
Really strange that this is better on my G1 uncalibrated.
I can see 69 faint on cmv2.9 4000 nits MDL.
And your test file called "cmv2.9 4000 nits MDL with Trims" I can see even 68 very faint.
I'm guessing something really changed starting from the c2/g2 series compared to c1/g1
daffie wrote:
Thu May 01, 2025 8:51 pm
@RESET
in 1h, I'm not home yet.
daffie wrote:
Thu May 01, 2025 9:23 pm
my C8 was the same as the C2 but Dolby did change something because the G1/C1 are the last TV to support Chroma Weight in cmv2.9, and now not even cmv4.0 CW works on the G5
@RESET
sorry, the 5-10% grayscales are too dim. My camera cannot capture it... I have to raise ISO, which introduces noise that masks the issue.
EDIT: actually what I'm seeing is exactly like in this video:
https://youtu.be/czIxtnAh36w?si=--UggVf0iEz5VP7u&t=350
foxbat
Post by foxbat »
RESET_9999 wrote:
Thu May 01, 2025 11:14 pm
@RESET
For what it's worth I've been watching movies in DV on my 83" G5 for a few weeks now and have not been able to see the dithering effect in any content in the darkest of scenes from my seating distance of 10' away. And believe me I looked.
foxbat wrote:
Fri May 02, 2025 2:28 am
Good to know, thanks. I haven’t noticed it in the two movies I’ve watched so far, but they were both bright 4000-nit grades. I do see the falling noise in the dark scenes from Dune samples, but not the diagonal lines which I only see in static images so far. Overall, I’m satisfied with the Dolby Vision performance. HDR10 is the only mode that looks bad, but I don’t really care since all my movies are in Dolby Vision anyway.
I’ve sampled a few FEL titles that expand the brightness range, and wow, what a difference.
Took a couple of pics from some FEL movies that expand brightness vs HDR10 (will be part of a much larger comparison on youtube): https://slow.pics/c/0Xy0y1Vw
These movies benefit a lot from a brighter TV...
Post by SamuriHL »
Maybe next year for me. I'm spending too much money this year on house repairs. But that does look promising. Maybe we'll hit 4000 at some point and be done with tone mapping altogether. I mean sure 10k but realistically if it's tone mapped to within 4000 who's really going to notice. LOL
Yeah, the G Series models are insanely expensive. I’m hoping I can hold off longer before upgrading again...
I got used to the ugly large vertical bars on my C2, but now that dark scenes are so much cleaner and with that incredible brightness, I think I’ll be able to resist the temptation for years.
Post by SamuriHL »
That's why I'm resisting. My g2 is no slouch. I get over 900 nits on it. Paired with the ugoos it's an amazing setup. The c8 is showing its age but for a bedroom TV it works very well.
daffie
Post by daffie »
Still happy here with my G1. Upgrading will be in 2 years maybe. Definitely not before.
@RESET
ugly large vertical bars on your C2?
What do you mean with this?
