BT - This Binary Universe - errors
captain
Post by captain » Tue Dec 20, 2011 3:13 pm
It seems to rip, but MakeMKV reported errors (see below) and it took a LOOOOOOONG time to rip. I think it reported 75min at one point, then hours at another - I left it overnight and came back to find it finished. This, for once, doe NOT appear to be a media error. :-)
Debug log started at Tue Dec 20 01:13:06 2011 , written by MakeMKV v1.6.16 darwin(x86-release)
001005:0000 MakeMKV v1.6.16 darwin(x86-release) started
001004:0000 Debug logging enabled, log will be saved as /MakeMKV_log.txt
002014:0000 Optical drive "DVD+R-DL OPTIARC DVD RW AD-5670S 2AHH" opened in DASPI v1.3 mode.
002014:0000 Optical drive "BD-ROM PLEXTOR BDDVDR PX-B310U 1.07" opened in DASPI v1.3 mode.
003019:0000 Cells 23-end were skipped due to cell commands (structure protection?)
003028:0000 Title #0 was added (14 cell(s), 1:15:38)
003019:0000 Cells 3-end were skipped due to cell commands (structure protection?)
003028:0000 Title #1 was added (2 cell(s), 0:08:37)
003028:0000 Title #2 was added (2 cell(s), 0:11:37)
003028:0000 Title #3 was added (2 cell(s), 0:10:42)
003028:0000 Title #4 was added (2 cell(s), 0:11:56)
003028:0000 Title #5 was added (2 cell(s), 0:14:38)
003028:0000 Title #6 was added (2 cell(s), 0:10:24)
003028:0000 Title #7 was added (2 cell(s), 0:08:34)
003019:0000 Cells 9-end were skipped due to cell commands (structure protection?)
003028:0000 Title #8 was added (8 cell(s), 1:16:53)
003025:0000 Title #9 has length of 17 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003019:0000 Cells 4-end were skipped due to cell commands (structure protection?)
003025:0000 Title #9/1 has length of 81 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title skip vts=2 pgcn=2 hash=F67BAC3938EDCD66
003025:0000 Title #9/3 has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #9/4 has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #9/5 has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #9/6 has length of 56 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #10 has length of 15 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #11 has length of 113 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #13 has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
005014:0000 Saving 9 titles into directory /Volumes/DVDs/THIS_BINARY_UNIVERSE
001003:0020 DEBUG: Code 301741 at E~TE`,Lmn<$_J!R]qk#:121265568
001003:0020 DEBUG: Code 47147 at E~TE`,Lmn<$_J!R]qk#:121265568
001003:0020 DEBUG: Code 64308 at E~TE`,Lmn<$_J!R]qk#:121265568
001003:0020 DEBUG: Code 411571 at E~TE`,Lmn<$_J!R]qk#:121265568
001003:0020 DEBUG: Code 58965 at E~TE`,Lmn<$_J!R]qk#:121265568
001003:0020 DEBUG: Code 377377 at E~TE`,Lmn<$_J!R]qk#:121265568
001003:0020 DEBUG: Code 65996 at E~TE`,Lmn<$_J!R]qk#:121265568
001003:0020 DEBUG: Code 422382 at E~TE`,Lmn<$_J!R]qk#:121265568
001003:0020 DEBUG: Code 81275 at E~TE`,Lmn<$_J!R]qk#:121265568
001003:0020 DEBUG: Code 520159 at E~TE`,Lmn<$_J!R]qk#:121265568
001003:0020 DEBUG: Code 57463 at E~TE`,Lmn<$_J!R]qk#:121265568
001003:0020 DEBUG: Code 367767 at E~TE`,Lmn<$_J!R]qk#:121265568
001003:0020 DEBUG: Code 46874 at E~TE`,Lmn<$_J!R]qk#:121265568
001003:0020 DEBUG: Code 300000 at E~TE`,Lmn<$_J!R]qk#:121265568
002008:0020 Program reads data faster than it can write to disk, consider upgrading your hard drive if you see many of these messages.
005005:0080 9 titles saved
005036:0104 Copy complete. 9 titles saved.
Re: BT - This Binary Universe - errors
Post by mike admin » Fri Dec 23, 2011 10:04 am
This should have fixed in the latest version, 1.7.0 . It's recommended to redo this title with this version anyway.
captain
Post by captain » Mon Jan 02, 2012 3:17 pm
Trying MakeMKV 1.7.0:
the following message is repeated a few hundred times:
DEBUG: Code 2281701379 at 9B0vv9Q+.v>JC"*M:213133917
until I "reregistered" with the new temporary key!.... Now I just get the messages like the following:
It seems to be ripping now, but reporting TEN HOURS remaining to rip a simple DVD. This seems wrong.
captain
Post by captain » Tue Jan 03, 2012 2:39 pm
During all of this current thrash to rip a DVD I also noticed that makemkvcon continues running even after I have quit MakeMKV. I have to go manually kill several instances of this errant process to get a clean start of makeMKV. This does not seem right to me.
captain
Re: BT - This Binary Universe - errors (solved by MakeMKV 1
Post by captain » Tue Jan 03, 2012 6:47 pm
1.7.0 ripped it! :-)
