LG WH14NS40 ready to flash?
TheJeffOfJeffs
Post by TheJeffOfJeffs »
Been using this drive with stock firmware for a little bit. I didn't have any issues with rips and it didn't seem to slow so flashing firmware felt unnecessary. Well, I finally hit a movie that won't rip - I think it has to do with region locking?
As far as I can tell this drive is okay to flash but would like someone smarter than me to verify.
Manufacture date looks good, SVC code is NS50. The one thing I wasn't sure about is the drive platform, but maybe I'm just misunderstanding that line in the guide, "2. Drive Platform MT1959<Most important in makemkv" viewtopic.php?f=16&t=19634
Any tips for flashing would be appreciated too!
Below is the drive info from MKV and a picture of the label on the drive.
Thank you!
OS device name: F:
Product: BD-RE WH14NS40
Revision: 1.05
Serial number: XXXXXXXXXXX
Highest AACS version: 62
Harware support: Yes
Firmware support: No
Firmware version: 1.05
Last edited by TheJeffOfJeffs on Wed Apr 30, 2025 12:16 am, edited 1 time in total.
Re: LG WH14NS40 ready to flash?
Post by d00zah »
Per the 1st post of the Ultimate UHD Drives Flashing Guide Updated 2025:
(HL-DT-ST-BD-RE_WH16NS60-1.02-NM00100-211810291936.bin)
Current v1.05 FW is encrypted. Use the SDFtool Flasher.
That said, knowing the type of disc & how it failed (log output) would go a long way to determining the issue.
TheJeffOfJeffs
d00zah wrote: Tue Apr 29, 2025 10:58 pm Per the 1st post of the Ultimate UHD Drives Flashing Guide Updated 2025:
The disc in question was a Bluray disc of The Boondock Saints. Below is the info from MakeMKV
Disc Information
Label: BOONDOCK_SAINTS
Timestamp: 2008-11-21 18:04:57
Protection: AACS v9, BD+ v2008.11
Data capacity: 41.40 Gb
Disc type: BD-ROM
Number of layers: 2
I'm attaching logs from MakeMKV as well.
It might be worth noting I'm also unable to play this movie in VLC, I'm met with a region lock message when I try. I thought that was odd seeing as I got this from the same place I get the rest of my movies- a local video buy & trade shop. I assume these two issues are related. Another interesting tidbit is that MakeMKV identifies two titles about the length of the movie, differing by less than a minute. "Extended Director's Cut" is listed in the special features, but you'd think that would be more than a few seconds longer, but I digress. One problem at a time.
MakeMKV Log.txt
(106.74 KiB) Downloaded 1753 times
