Stop MacOS from Asking To Access External Drive
psycoperl
Post by psycoperl » Fri Dec 06, 2024 2:23 pm
Is there a way in MacOS 15 to stop having it ask to allow MakeMKV to access the Bluray Drive after each disk is inserted?
Each time I change the disk in the bluray drive and go to rip the disk, MakeMKV/MacOS prompts to allow access to external device/
loinful
Re: Stop MacOS from Asking To Access External Drive
Post by loinful » Tue Dec 10, 2024 3:30 am
In macOS 15 (Sonoma), the system introduces stricter security measures around application access to external devices, like Bluray drives. To stop macOS from asking for permission every time you insert a new disk, you can grant permanent access to MakeMKV for the Bluray drive. Here's how to do it:
### Steps to Allow Permanent Access:
1. **Go to System Settings**:
- Click the Apple menu in the top-left corner.
- Select **System Settings**.
2. **Navigate to Privacy & Security**:
- Scroll down and select **Privacy & Security**.
3. **Check Removable Volumes Permissions**:
- Under the Privacy section, locate **Files and Folders**.
- Look for **MakeMKV** in the list of apps.
- Ensure it has the necessary permissions to access **Removable Volumes** or **External Devices**.
4. **Adjust Full Disk Access** (if needed):
- In **Privacy & Security**, select **Full Disk Access**.
- If MakeMKV isn’t already listed, click the **+** button and add it from your Applications folder.
- Toggle the switch to enable Full Disk Access.
5. **Restart MakeMKV**:
- After adjusting permissions, close and reopen MakeMKV to ensure the changes take effect.
### Notes:
- If the above steps do not resolve the issue, you may need to check the specific drive's permissions. Some drives may be treated differently by the system due to how they're recognized.
- Keep macOS and MakeMKV updated to ensure compatibility with the latest security protocols.
If the issue persists despite these adjustments, consider reaching out to MakeMKV's support forums or macOS support for further troubleshooting.
Powerkey
Post by Powerkey » Sat Feb 15, 2025 10:22 pm
Has something changed regarding this procedure?
Ever since installing 1.17.9 a few weeks ago, MakeMKV always asks for permission to access removable drives (I have 2 the drive and an external SSD I use for ripping, etc).
I followed these steps and it is still asking.
I am on macOS 15.3.
hedcase
Post by hedcase » Thu Apr 10, 2025 9:18 pm
I'm having similar issues lately. MakeMKV will ask for permissions a couple times during a single disc rip. I've checked all the permissions -- seems to check out fine there.
austeros
Post by austeros » Mon Apr 14, 2025 11:45 pm
Having this problem too on 15.4 with 1.18.1 installed.
ToddUGA
Post by ToddUGA » Tue Apr 29, 2025 12:51 pm
Something is definitely broken in 1.18.1. Tried all of the tips here but I still can't save to disk and still get asked to access drives every time.
820am
Post by 820am » Sun Oct 05, 2025 1:24 pm
Having the same problem in MakeMKV 1.18.2 on MacOS 15.6.1.
I swear there was a terminal command that made it stop asking for disk permissions but I'll be danged if I can find it anywhere
Post by dcoke22 » Tue Oct 07, 2025 3:25 pm
This perhaps? https://forum.makemkv.com/forum/viewtopic.php?f=4&t=36827
MooseJaw
Post by MooseJaw » Tue Dec 09, 2025 2:36 pm
Privacy & Security -> Files & Folders -> Expand MakeMKV.app -> Enable Removable Volumes
