Improving vocals from Blu-rays?
Bsmooth
#1 Post by Bsmooth » Tue Apr 22, 2025 1:51 pm
Just started getting my blurays discs on a hardrive using MKV and Handbrake. I'm a bit on in years and I guess my hearing isn't what it used to be. I'm finding it a bit difficult hearing vocals from movies after I get the files onto my HD. I'm watching on a pretty old Samsung, but no night settings to play with.
In your experience is there a way to improve settings in Handbrake to improve the vocals a bit? I read you can set the audio Dynamic compression between 1 and 2.5, but not sure where might be the best place.
Its strange If I watch the same movie being broadcast the vocals seem fine, but from a bluray rip they are very quiet.
Also do the audio settings like mixing from say an AC3 to AAC make a difference in vocals as well, lots of options here. Right now I mix them down to stereo, but maybe lose vocals in the process somewhere?.
I also have subtitles on and usually have a few choices including SRT files as well.
Any help would be greatly appreciated.
jinx100
Re: Improving vocals from Blu-rays?
#2 Post by jinx100 » Tue Apr 22, 2025 3:20 pm
The vocals are difficult to discern on some films. I think it is just bad sound engineering on some newer films. My Handbrake process is like yours, reducing the 5.1 channel to AAC stereo. Maybe someone with a theater sound system will comment if that helps the vocals.
My profile for blu-ray discs does add 6 db gain to the audio but no dynamic compression. The dynamic compression just seems to raise the background noise in the quieter audio sections of the film.
Bsmooth
#3 Post by Bsmooth » Tue Apr 22, 2025 3:43 pm
I was hoping the Dynamic Compression would help. Its frustrating, finally getting the nice clear video and the Audio not keeping up.
Bsmooth
#5 Post by Bsmooth » Tue Apr 22, 2025 7:24 pm
Thats a great article, reminds me a bit about the Loudness wars we had a few years ago with music CD's and how it was mixed. I love it, technology jumps ahead leaps and bounds, and we get dialogue we can't understand. A lot of it sound like just plain laziness. Don't they get it? Its a package deal, sound and video. A lot of us have these great killer Home Theater setups, and by the time we get the actual movie, it all falls apart.
Thing is though If one can get it right, they all can. Its going to get to the point we'll have to listen to it in Mono, wouldn't that be sad.
So If cutting back on DR won't help, what will?
jinx100
#6 Post by jinx100 » Tue Apr 22, 2025 7:56 pm
Check what audio adjustments are on your TV. Anything to reduce the bass should make the dialog more prominent.
#7 Post by dcoke22 » Tue Apr 22, 2025 9:35 pm
In my view, the best improvement one can make is to use a dedicated speaker setup as opposed to whatever speakers come in the TV. Most experiences I've had with speakers built into a TV have been terrible.
Bsmooth
#8 Post by Bsmooth » Fri Apr 25, 2025 7:09 pm
Is there a away to run it thru Audacity somehow, without it taking 2 hours? Or maybe seperate the vocals and then run it thru Audacity?
#9 Post by dcoke22 » Sun Apr 27, 2025 4:41 pm
There are plugins that can isolate vocals/dialog from a track. I haven't used them, so I can only speculate. For example:
https://plugins.audacityteam.org/ai-plugins/ai-plugins
https://www.izotope.com/en/products/rx/features/dialogue-isolate.html
You could use MKVToolNix to move an audio track from a .mkv file into its own separate file, process it in Audacity or whatever to boost the vocals, then use MKVToolNix to put the updated audio back into the .mkv file.
Some playback systems like JRiver Media Center allow for using various plugins during playback. I don't know if they have some kind of vocal boost plugin that could be used in real time. I'm a Plex user, so all I know about JRiver MC is what I read on the internet. :)
Bsmooth
#10 Post by Bsmooth » Tue Apr 29, 2025 12:40 am
I keep forgetting how versatile MKVToolNix is. Yes your quite right , I could use it to do that, although I must admit, its not something I've done before. Give me something to fool around with.
safariff
#11 Post by safariff » Tue Dec 30, 2025 11:44 pm
https://gist.github.com/seamonkey420/a3 ... b22def7b5a
This script has served me well in the past.
Bsmooth
#12 Post by Bsmooth » Sun Mar 22, 2026 4:26 pm
Well I've been busy updating the audio in my movies by taking them out and boosting the vocal parts separately. So far only in stereo, which I know isn't the greatest, but now it works and the loud parts don't blow you out of the room.
Last one I finished is The Hunt for Red October.
So basically I take the 5 channel audio out using MKVToolnix and then convert it to stereo in Audacity. Then from there go in and first lower the loudest parts, and also boost the vocal parts. It sounds simple but it literally takes quite a few hours. There's also some compressing involved for very softer vocal parts.
I learned more from this one, especially since its a sub movie with all sorts of little humming going on in the background.
So If anyone is interested I have the sound file which you can just put into your movie using MakeMKV.
