Tombstone Alternate Variant (3B88)
queeg500
Post by queeg500 » Mon Apr 28, 2025 12:58 pm
I have the Steelbook UK version of Tombstone which seems to be an Alternate Variant (3B88) and cannot be decrypted. I have emailed sqvmakemkv with the .tgz for this. Im using the latest Keydb.cfg. Anyone else have this version ??
Regards, D
keydb_helper
Re: Tombstone Alternate Variant (3B88)
Post by keydb_helper » Mon Apr 28, 2025 1:20 pm
Regards, D
If you would like to see support for your disc added to the public keydb, you'll need to provide a suitable disc dump. This can be either an attachment or a link to a file host. Otherwise you'll probably need to wait for native MakeMKV support.
Public KeyDB Disc Submissions
SpaceCowboy87
Post by SpaceCowboy87 » Mon Apr 28, 2025 1:53 pm
Would this be of any help? Was just about to post this myself but appears to be the same file mentioned here
keydb_helper
Post by keydb_helper » Mon Apr 28, 2025 2:05 pm
Thanks for the disc dump file. The 3B88 variant of Tombstone has been added to the public keydb.
queeg500
Post by queeg500 » Mon Apr 28, 2025 3:11 pm
Thank you for doing that. Its appreciated.
