Tombstone Alternate Variant (3B88)
queeg500
#1 Post by queeg500 » Mon Apr 28, 2025 12:58 pm
I have the Steelbook UK version of Tombstone which seems to be an Alternate Variant (3B88) and cannot be decrypted. I have emailed sqvmakemkv with the .tgz for this. Im using the latest Keydb.cfg. Anyone else have this version ??
Regards, D
keydb_helper
Re: Tombstone Alternate Variant (3B88)
#2 Post by keydb_helper » Mon Apr 28, 2025 1:20 pm
queeg500 wrote: Mon Apr 28, 2025 12:58 pm Hi,
Regards, D
If you would like to see support for your disc added to the public keydb, you'll need to provide a suitable disc dump. This can be either an attachment or a link to a file host. Otherwise you'll probably need to wait for native MakeMKV support.
Public KeyDB Disc Submissions
SpaceCowboy87
#3 Post by SpaceCowboy87 » Mon Apr 28, 2025 1:53 pm
Would this be of any help? Was just about to post this myself but appears to be the same file mentioned here
keydb_helper
#4 Post by keydb_helper » Mon Apr 28, 2025 2:05 pm
SpaceCowboy87 wrote: Mon Apr 28, 2025 1:53 pm Would this be of any help? Was just about to post this myself but appears to be the same file mentioned here
Thanks for the disc dump file. The 3B88 variant of Tombstone has been added to the public keydb.
queeg500
#5 Post by queeg500 » Mon Apr 28, 2025 3:11 pm
keydb_helper wrote: Mon Apr 28, 2025 2:05 pm
Thank you for doing that. Its appreciated.
