I have the Steelbook UK version of Tombstone which seems to be an Alternate Variant (3B88) and cannot be decrypted. I have emailed sqvmakemkv with the .tgz for this. Im using the latest Keydb.cfg. Anyone else have this version ??
Regards, D
Tombstone Alternate Variant (3B88)
keydb_helper
Re: Tombstone Alternate Variant (3B88)
If you would like to see support for your disc added to the public keydb, you'll need to provide a suitable disc dump. This can be either an attachment or a link to a file host. Otherwise you'll probably need to wait for native MakeMKV support.queeg500 wrote: Mon Apr 28, 2025 12:58 pm Hi,
Regards, D
Public KeyDB Disc Submissions
SpaceCowboy87
Would this be of any help? Was just about to post this myself but appears to be the same file mentioned here
keydb_helper
Thanks for the disc dump file. The 3B88 variant of Tombstone has been added to the public keydb.SpaceCowboy87 wrote: Mon Apr 28, 2025 1:53 pm Would this be of any help? Was just about to post this myself but appears to be the same file mentioned here
Thank you for doing that. Its appreciated.keydb_helper wrote: Mon Apr 28, 2025 2:05 pmThanks for the disc dump file. The 3B88 variant of Tombstone has been added to the public keydb.SpaceCowboy87 wrote: Mon Apr 28, 2025 1:53 pm Would this be of any help? Was just about to post this myself but appears to be the same file mentioned here
