Blu-ray rip convert into iso (imgburn)
chihwahli
#1 Post by chihwahli » Sat Apr 26, 2025 8:59 am
I did not read MakeMKV posts about this, but did you peeps know that you can convert the bluray ripped files right back into a iso file again? Pity MakeMKV does not do this automatically at ripping, as with DVD. Bluray always get saved a folders and files on the computer.
But, Imgburn program converts the ripped files and folders directly as a iso file again, and you can play it in VLC.
Ezatoka
Re: Blu-ray rip convert into iso (imgburn)
#2 Post by Ezatoka » Sat Apr 26, 2025 9:44 pm
chihwahli wrote: Sat Apr 26, 2025 8:59 am But, Imgburn program converts the ripped files and folders directly as a iso file again, and you can play it in VLC.
You can play the folder with VLC as well, so why make it into an ISO?
Just go to Open Media -> Disc -> Blu-ray and there you enter the path to the directory, where the BDMV directory is inside (basically the root of the BluRay).
Keloid
#3 Post by Keloid » Sun Apr 27, 2025 2:26 am
I assume that you need original filesystem structure thingy from blu-ray. In some cases, such as 3D BD or MGVC, It can be critical. Unfortunately, ISO burn is not helpful for this. It will just repacking extracted files. Like Ezatoka said, It's pointless. Unless you have your own reason for keeping BDMV as a single file.
In the other hand, if you need truly necessary ISO ripping, MakeMKV is not able to do it. xreveal is the only option I believe.
chihwahli
#4 Post by chihwahli » Mon Apr 28, 2025 11:53 am
ISO has it's benefits:
- 1 file only
- dvd / bluray menu intact
- movie files sometimes cut into a billion pieces and you can hunt down the order of things
DVD is by default ripped as iso, perfect.
Bluray not. It just creates the folders and files.
So I use IMGBurn to re-create MakeMKV output as iso again.
Saves a lot of problems with movies like fast and the furious 6 and 7 for example.
The main movie is cut into many small pieces.
Ezatoka
#5 Post by Ezatoka » Mon Apr 28, 2025 12:17 pm
chihwahli wrote: Mon Apr 28, 2025 11:53 am The main movie is cut into many small pieces.
where is that a problem if you just let MakeMKV make a single MKV file out of them? Actually you can do so with just any video on the disc, then you wouldn't need the menus anymore. Yes, it's work to do, once. But then you have files like
Sonic the Hedgehog 3\Sonic the Hedgehog 3 (UHD).mkv
Sonic the Hedgehog 3\Extras\A Very Sonic Christmas.mkv
Sonic the Hedgehog 3\Extras\Enter Shadow.mkv
Sonic the Hedgehog 3\Extras\For the Love of Sonic∶ Directing a Trilogy.mkv
Sonic the Hedgehog 3\Extras\From the Cryo-Tank to London∶ The World of Sonic.mkv
Sonic the Hedgehog 3\Extras\Gag Reel.mkv
Sonic the Hedgehog 3\Extras\Live-Action Lunacy∶ Acting opposite Puppets.mkv
Sonic the Hedgehog 3\Extras\Robotnik Family Reunion∶ Ivo and Gerald.mkv
Sonic the Hedgehog 3\Extras\Sonic Family Fun.mkv
Sonic the Hedgehog 3\Extras\Team Sonic vs. Shadow.mkv
Sonic the Hedgehog 3\Extras\The Fox, the Echidna, and the Hedgehog.mkv
Sonic the Hedgehog 3\Extras\Deleted Scenes\Bea Arthur Cake.mkv
Sonic the Hedgehog 3\Extras\Deleted Scenes\G.U.N. Selfie.mkv
Sonic the Hedgehog 3\Extras\Deleted Scenes\Gerald claps back.mkv
Sonic the Hedgehog 3\Extras\Deleted Scenes\Ivo and Gerald Bonding.mkv
Sonic the Hedgehog 3\Extras\Deleted Scenes\Ivo and Gerald hide.mkv
Sonic the Hedgehog 3\Extras\Deleted Scenes\Ivo Live Stream 1.mkv
Sonic the Hedgehog 3\Extras\Deleted Scenes\Ivo Live Stream 2.mkv
Sonic the Hedgehog 3\Extras\Deleted Scenes\Stone Saves Ivo.mkv
