Hi! I'm new here. Today I've bought my 1st BD Drive.
It is ASUS BW-12D1S-U. Is it possible to flash it for UHD BD?
I'm reading that user "Coopervid" maybe knows how! Is it right? Can you help me? Thank You very much.
OS device name: /dev/rdisk7
Current profile: CD-ROM
Manufacturer: ASUS
Product: BW-12D1S-U
Revision: E102
Serial number: ...
Firmware date: 2011-05-06
Bus encryption flags: 13
Highest AACS version: 68
Status: Possible, but very unlikely to happen
Drive platform: Pioneer RS1030
Firmware version: ID71
ASUS BW-12D1S-U
Re: ASUS BW-12D1S-U
No.highcollar wrote: Mon Mar 31, 2025 7:45 pm Hi! I'm new here. Today I've bought my 1st BD Drive.
Manufacturer: ASUS
Product: BW-12D1S-U
Revision: E102
Serial number: ...
highcollar
Re: ASUS BW-12D1S-U
Why not? It is not possible? Thank U
Re: ASUS BW-12D1S-U
Guessing that being built over 4 years before UHD was invented affects the compatibility...
PurpleHaze
Re: ASUS BW-12D1S-U
Does anybody know if the ASUS BW-12D1S-U, can rip normal 1080p blurays?
Because I have found one sold for 50euro.
Re: ASUS BW-12D1S-U
It should work but I wouldn't buy it. LG type drives are shortlived anyway.PurpleHaze wrote: Sun Apr 27, 2025 3:52 pm Hello,
PurpleHaze
Re: ASUS BW-12D1S-U
Thank you for your answer, so you think it is better to save more and buy something with pioneer for about 120euro?Coopervid wrote: Sun Apr 27, 2025 8:34 pmIt should work but I wouldn't buy it. LG type drives are shortlived anyway.PurpleHaze wrote: Sun Apr 27, 2025 3:52 pm Hello,
I'm only saying it cause my budget is pretty tight right now and to me it sounded like a good deal. However I'm a complete novice when it comes to ripping.
