Post
by Billycar11 »
testt wrote: Mon Jun 24, 2024 9:40 pm
yes i did that before but now that may have worked
it did work thanks i am wondering on why it needed to be flashed
because companies dont want your ripping UHD so they patch it out of FW
old fw has an exploit used to to rip UHD
Post
by d00zah »
It needed to be flashed to enable LibreDrive.
From the SDFTool GUI notes:
Usage:
Make sure the drive is empty and tray is closed.
Post
by Coopervid »
Don't post as hell and READ. You need to flash your drive.
Androusa88
Post
by Androusa88 »
Hi everyone, I have the same problem to rip my BD, that my information :
OS device name: /dev/rdisk4
Manufacturer: PIONEER
Product: BD-RW BDR-UD04
Revision: 1.14
Serial number: ...
Firmware date: 2020-06-15
Highest AACS version: 77
Drive platform: RS8A10
Firmware version: 1.14
Can anyone help me? Thanks in advance
