Can I merge my own firmware with the backup tar files ?
I have dump_user_ASUS_BW-16D1HT_3.11_212012011759_KL8O22A1834.tar my orginal firmware files chunk
fd_fwdate.bin
fd_sn.bin
inq.bin
rom_003000.bin
rom_1EC000.bin
rom_1F0000.bin this 6 files
how can ı make my own orginal firmware with sdf_00000097.bin and this 6 files ?
Thank you in advance
Can I Merge My Own Firmware ?
Re: Can I Merge My Own Firmware ?
can you yes
should you no
but you need stock asus 3.11 and then to merge your data in
and no one has that except asus and mike
why do you want to do this besides tinkering
should you no
DarkFrost89
because ı just make my own orginal firmware, if have any problem with my drive ı turn back my own firmware, it's just thatBillycar11 wrote: Sat Apr 26, 2025 8:25 am can you yes
should you no
Thats nuts! And as far as I can tell from our conversations you are lacking a lot of background knowledge. So don't even think about stuff like that.DarkFrost89 wrote: Sat Apr 26, 2025 9:11 ambecause ı just make my own orginal firmware, if have any problem with my drive ı turn back my own firmware, it's just thatBillycar11 wrote: Sat Apr 26, 2025 8:25 am can you yes
should you no
