BU40N CB05
JaseVernon
BU40N CB05
Post by JaseVernon » Sat Apr 26, 2025 2:13 am
Hi Everyone,
I am new here and learning...or at least trying to. When I bought my drive I was told it was a different revision than it is. It came from a long way so I am no sure I care to return it unless absolutely necessary. I have been trying to figure out if anything is available to flash this drive, but Ionly found 1 post from 2018 refrencing it. Does anyone know if I can do UHD with this drive or am I out of luck?
Thank you!
Re: BU40N CB05
Post by Billycar11 » Sat Apr 26, 2025 5:26 am
see guide below
JaseVernon
Re: BU40N CB05
Post by JaseVernon » Sat Apr 26, 2025 6:04 am
Yes I was going through tthat but then saw my revision of CB05 and searched it and saw this
viewtopic.php?f=16&t=16832&p=63928&hilit=CB05#p63928
In there it says "Specifically at the post from "mike admin" who is the owner/developer of MakeMKV. That drive with its stock firmware is currently NOT supported for UHD ripping/decrypting by MakeMKV. Once it's supported, Mike will advise/announce. For immediate support with that drive at this time you need to use different software."
But then I never saw anything more about it anywhere. So I am concerned about flashing it after reading that.
Re: BU40N CB05
Post by Billycar11 » Sun Apr 27, 2025 1:23 am
JaseVernon wrote: Sat Apr 26, 2025 6:04 am Yes I was going through tthat but then saw my revision of CB05 and searched it and saw this
it works man 2018 is before mk fw and stuff
that post from alex is 7 years old my guide was updated this year
and if you look at alex's recent reviews you can see how reliable he is
viewtopic.php?f=20&t=17829
JaseVernon
Re: BU40N CB05
Post by JaseVernon » Sun Apr 27, 2025 5:08 am
Ok thank you...I have a drive so I don't want to buy another one, plus I am in Canada. So I will try and follow the guide and see what I can do
Jase
