WARRIOR Bluray Which Source to pick?
herbcheck
#1 Post by herbcheck » Tue Dec 20, 2011 4:58 pm
When opening WARRIOR on bluray i gets ton of .mpls files. There are over 20+. Does anyone know the correct source code or running time to choose?
<a href="http://s675.photobucket.com/albums/vv11 ... 5631AM.png" target="_blank"><img src="http://i675.photobucket.com/albums/vv11 ... 5631AM.png" border="0" alt="Photobucket"></a>
Screen Shot 2011-12-20 at 8.56.31 AM.png (397.13 KiB) Viewed 27574 times
mbryanr
Re: WARRIOR Bluray Which Source to pick?
#2 Post by mbryanr » Tue Dec 20, 2011 9:14 pm
herbcheck
#3 Post by herbcheck » Wed Dec 21, 2011 1:02 am
setarip_old
#4 Post by setarip_old » Wed Dec 21, 2011 1:49 am
When confronted with what initially looks like a monstrosity (appears to put "Source Code" to shame), you can always simply use MakeMKV to make a "Full Disc" copy instead of a "movie-only" .MKV...
#5 Post by mike admin » Fri Dec 23, 2011 9:57 am
This is so called "structure protection" for blu-ray. It's also incorrectly called "java protection" as java is not always used with these discs. The disc contains a lot of "junk" content on purpose. This "junk" contents is properly authored, so unlike DVD, it's very hard to distinguish it from a normal titles. The current version of MakeMKV can't indicate which title is right one and which one is fake. This functionality is obviously coming very soon, as more and more discs use such protection.
setarip_old
#6 Post by setarip_old » Sat Dec 24, 2011 12:42 am
And mike admin's latest post to this thread indicates that the protection on the "Warrior" Blu-ray disc now makes my suggestion obsolete...
KENSAI
#7 Post by KENSAI » Thu Jun 21, 2018 2:19 am
So I'm trying to rip the Blu-ray I own for this (retail copy) and am struggling: there's no way I can see to copy the full disc, the link to the site that has the correct order is dead, and the one I tried a couple of years ago ended up being the wrong one. There's no Java protection, so that's not a solution. I'm at a loss here and I can't find the answer anywhere. Any suggestions?
werepancake
#8 Post by werepancake » Fri Nov 02, 2018 2:33 am
So according to https://forum.redfox.bz/threads/warrior-issue.51550/ the correct playlist should be should be 00789.mpls.
This is unconfirmed by me personally, I'll update this post once I get around to watching it.
Edit: The above playlist is correct.
93cat
#9 Post by 93cat » Sat Jun 07, 2025 10:19 pm
Can anyone share the source file name &/or segment map for this version of Warrior 2011?
I think I have this 2014 Region A release/version:
https://www.blu-ray.com/movies/Warrior-Blu-ray/153447/
Java did not detect the correct title, and I can't find this info anywhere.
00789.mpls is not an option, so I must have a different version than werepancake.
I searched avsforum too, no joy.
Help!?! Thanks!
