Hi all,
Blu-Ray : The Game Plan
MakeMKV (1.6.16) can't detect English and French DD 3/2+1 and DTS 3/2+1 audio tracks.
Just a poor DD 2/0.
Moreover it detect a 2:07 hours film instead of 1:50 hours film.
Audio tracks not detected
- 2011-12-20_121917.png (97.4 KiB) Viewed 11022 times
Re: Audio tracks not detected
turn on debugging and post the log as explained here:
http://www.makemkv.com/faq/item/8
setarip_old
@NotMe
Hi!
Have you scrolled down through ALL of the titles?
Based on your observation that the title you selected has an excessive total runtime, I'd speculate that this is a typical feeble protection effort by Disney, whereby a fake title (.MPLS) is created as the largest title listed - because many ripping programs assume the largest title is the movie.
If you scroll through ALL of the titles, I'm guessing you'll find a title with the correct runtime and filesize - perhaps it'll be 00800.MPLS.
Please post back here to let us know...
Hi!
@Old_Pirates
Yes, I know the power of a scrollbar
- PLAYLIST.ZIP
- (71.97 KiB) Downloaded 428 times
- CLIPINF.ZIP
- (173.21 KiB) Downloaded 423 times
- 2011-12-21_090803.png (95.47 KiB) Viewed 11007 times
- Contact:
Most likely this is a bug that will be fixed in a next version. To confirm, can you please post another screenshoot that shows the same GUI title tree, but where the specific title in tree is selected. You need to find a title that will have the following property shown in right info pane: "source file name: 00138.mpls". Most likely it's a 23 chap 2.2GB one.
You are right Mike.
The new version (1.7.1) do the job.
Thank you.
Thank you.
- 2012-01-29_142606.png (112.32 KiB) Viewed 10891 times
