Hi. Is it possible to include pics or/and synopsis into an mkv movie so that one can have it before playing back movie?
Thank you
Including pictures or synopsis in a mkv
Re: Including pictures or synopsis in a mkv
Are you asking if this is possible with the mkv-format, or are you asking for it as a feature in makemkv?
mkv-files can have attachments of any kind. However, for these attachments to be useful, you have to establish a convention that's supported among players. At the moment, there is only one convention, and that is for cover images.
You can read about that here: http://matroska.org/technical/cover_art/index.html
In theory, attaching a synopsis as "synopsis.txt" is simple. However, for it to be useful, you'll have to convince those that makes the players to use this attachments.
Thank you for your help. Actually I wanted to know both.
I have tested my media player (Xtreamer Pro) and for now it does NOT work.
A question : how to with makemkv?
Regards
Regards
- Contact:
MakeMKV doesn't attach cover art now. It's a planned feature. For now, you can attach covert art picture from blu-ray folder BDMV/META/DL into produced MKV file by hand, there are plenty of tools.
