What do I do with all the MKV files?
drewchas
Post by drewchas » Sun Apr 06, 2025 3:33 pm
Hi, all.
I'm ripping Blu-Rays for the first time.
I see that MakeMKV rips a bunch of files in addition to the large file of the movie.
Do I just create a folder on my external hard drive with the title of the movie and dump all the files into it?
Also, how do I play the movie, and how do I play the movie with the English subtitles--if available--turned on?
Apologies: I'm a newbie.
Thanks in advance,
Andrew
Re: What do I do with all the MKV files?
Post by Woodstock » Sun Apr 06, 2025 9:37 pm
You can reduce the number of files ripped in a variety of ways.
One is to set the minimum time above 120 seconds; some people use 1800 seconds (30 minutes) minimum, but that limits you when ripping things like TV series.
Another is to simply deselect things you're not interested in. That's what the little check boxes next to each title will do.
Some people (like me) rip everything over 2 minutes and watch the short videos once, then toss them. Sometimes, they're interesting. Other times, they're promos for other titles.
Dan'o
Post by Dan'o » Thu Apr 24, 2025 3:22 pm
Woodstock,
Well I can RIP the UHD files easily now with MKV, BUT, I can't merge all the files into one! I got MKVTOOLNIX but nothing seems to be working to merge them all into ONE PLAYABLE FILE. Can you help or send me in a direction to get the process down? I have done it one time (FLUKE) I think, because I couldn't get it to do it again. I am just missing some step or something. I put all the MKV pieces into the TOOL and then go to MULTIPLEX them but I get an immediate error. I think it is just me... for sure, because I have not used this before. Can you help or explain how to get all the 't' files into one PLAYABLE?
Thanks in advance... Dan'o
Post by dcoke22 » Fri Apr 25, 2025 1:15 pm
Dan'o wrote: Thu Apr 24, 2025 3:22 pm Woodstock,
Out of curiosity, why are you trying to merge multiple .mkv files together?
Post by d00zah » Fri Apr 25, 2025 2:06 pm
While there may be better ways to go about this, the simple answer to your question is to choose "Append files" in the MKVToolNix UI, rather than "Add files". The result will be a concatenation of all the selected files (without a menu).
crazyg0od33
Post by crazyg0od33 » Wed Jul 09, 2025 2:09 pm
dcoke22 wrote: Fri Apr 25, 2025 1:15 pm
also a bit confused by the question - when I run makemkv and deselect everything except the one main "title" that I'm ripping, I only get one single MKV file to put into mkvtoolnix at the end...
