ASUS SBW-06D2X-U
larsd
Re: ASUS SBW-06D2X-U
Post by larsd »
Hello @Coopervid? Or anyone with the same drive?
SIRSH
Post by SIRSH »
OS device name: E:
Manufacturer: ASUS
Product: SBW-06D2X-U
Revision: A102
Serial number: ...
Firmware date: 2121-06-28 13:41
Bus encryption flags: 1F
Highest AACS version: 68
I would like to flash my drive can someone help with directions
SIRSH wrote: Wed Apr 23, 2025 5:15 pm Drive Information
OS device name: E:
Manufacturer: ASUS
Revision: A102
Serial number: ...
oh no they changed that one too they went from pioneer to LG oh well treat it as a bu40n with enc I assume see guide below
Dreggie
Post by Dreggie »
i have folloing one:
Laufwerksinformation
OS-Gerätename: E:
Produzent: ASUS
Produkt: SBW-06D2X-U
Revision: 1.10
Serienummer: ...
Firmware-Datum: 2017-04-18
Highest AACS version: 21
Firmware version: ID22
is it flashable?
django58
ASUS SBW-06D2X-U
Post by django58 »
Hello, I hope you can help me too. I have the same drive.
OS-Gerätename: F:
Produzent: ASUS
Revision: 1.10
Serienummer: ....
Many thanks in advance.
SlowUser
Post by SlowUser »
Hello, I have the following external ASUS drive:
Manufacturer: ASUS
Revision: 1.10
Serial number: xxxxxxxxxx
Firmware date: 2017-04-18
Highest AACS version: 71
Drive platform: RS8510
Firmware version: 1.10/ID22
I would like to flash it to make it UHD-friendly. I checked viewtopic.php?f=16&t=19634 and downloaded the "all you need firmware pack" but I do not know which firmware in the pack is the correct one for my drive. Can you please help me?
SlowUser wrote: Fri Apr 25, 2025 9:02 am Hello, I have the following external ASUS drive:
Manufacturer: ASUS
Revision: 1.10
sure email me that info
that pack is for lg drives not pioneers
django58
Post by django58 »
django58 wrote: Thu Apr 24, 2025 8:50 pm Hello, I hope you can help me too. I have the same drive.
OS-Gerätename: F:
Produzent: ASUS
Revision: 1.10
Serienummer: ....
Hi Coopervid, can you help me please to flash my drive with libredrive firmware. Thanks a lot.
ops345
Post by ops345 »
hello all,
Newbie here.
I just purchased this drive, the ASUS SBW-06D2X-U with build date of July 2024. I've tried to copy my personal 3D blu-rays with with makemkv so that I can stream them with my NAS/Server instread of using my clunkly blu-ray player but the process failed everytime. It would start, and after sometime, it would just end in failure.
I'm using everything stock.
Do I need to "flash" this drive, or why do I need to flash this drive, what does it add and will this solve the issues I was having? I know thats hard to answer without logs.
I'm not interested in 4K blu-rays, as im strickly using this for a 3D movie collection (which are all 1080p).
thanks for your help
ops345 wrote: Tue Apr 29, 2025 6:52 pm hello all,
Newbie here.
You are good.
django58 wrote: Mon Apr 28, 2025 8:11 pm
OS-Gerätename: F:
Produzent: ASUS
Revision: 1.10
Serienummer: ....
PM sent.
django58
Post by django58 »
Coopervid wrote: Tue Apr 29, 2025 9:47 pm
OS-Gerätename: F:
Produzent: ASUS
Revision: 1.10
Serienummer: ....
PM sent.
Thanks a lot
Hamiltonblue
Post by Hamiltonblue »
Good Afternoon
I have the same drive:
Any help would be apprciated.
So far finding the correct file has been challenging :(
Thank You
OS device name: E:
Manufacturer: ASUS
Revision: A102
Serial number:
Highest AACS version: 17
Disc Information
Label: KILLBILL1_US
Timestamp: 2008-07-29 11:25:00
Protection: AACS v7
Data capacity: 46.61 Gb
Disc type: BD-ROM
Number of layers: 2
Hamiltonblue wrote: Wed May 14, 2025 3:14 pm Good Afternoon
Thank You
OS device name: E:
Manufacturer: ASUS
Revision: A102
Serial number:
Disc Information
Label: KILLBILL1_US
Protection: AACS v7
Disc type: BD-ROM
Number of layers: 2
You have a LG drive and need to follow this guide:
Hamiltonblue
Thank You
I used the SDF tool and tried to load THE DE_LG_BU40N_103_MK.bin
I received the error oxff056103 Tried the other LG 1.03 files and had the same message.
I see on the first link that thre is an Autoflash kit for $25.00
What is that, and would it be the best way to go without bricking the drive?
