PM sent.
Pioneer BDR-UD03 UHD possibility
Re: Pioneer BDR-UD03 UHD possibility
I almost threw away a Verbatim drive with a faulty enclosure until I decided to open it and discovered it was a Pioneer UD03 inside. The manufacture date is 2011 on the sticker, but the firmware date is 2018.
Drive information as follows:
Needless to say I instantly pulled it out of its enclosure and put it in another one. I'd love to get this cross-flashed to a UD04 and would appreciate any instructions on how to do this.
Thanks.
Current profile: BD-RE
Manufacturer: PIONEER
Product: BD-RW BDR-UD03
Revision: 1.11
Serial number: SJDL272698WL
Firmware date: 2018-11-28
Drive platform: RS8511
Firmware version: 1.11
Disc Information
Data capacity: 93.22 Gb
Thanks.
sure email me that info see belowVA1DER wrote: ↑Thu Apr 24, 2025 5:16 amI almost threw away a Verbatim drive with a faulty enclosure until I decided to open it and discovered it was a Pioneer UD03 inside. The manufacture date is 2011 on the sticker, but the firmware date is 2018.
Drive information as follows:Needless to say I instantly pulled it out of its enclosure and put it in another one. I'd love to get this cross-flashed to a UD04 and would appreciate any instructions on how to do this.Code: Select all
Drive Information OS device name: D: Current profile: BD-RE Manufacturer: PIONEER Product: BD-RW BDR-UD03 Revision: 1.11 Serial number: SJDL272698WL Firmware date: 2018-11-28 Bus encryption flags: 1B LibreDrive Information Status: Enabled Drive platform: RS8511 Firmware name: PIONEER BDR-US03 Firmware type: Original (unpatched) Firmware version: 1.11 DVD all regions: Yes BD raw data read: Yes BD raw metadata read: Yes Unrestricted read speed: Yes Disc Information Data capacity: 93.22 Gb
Thanks.
Done. Check your spam folder, my provider's emails tend to end up there on gmail.
Hello Billy,
My flashed Verbatim Lg-Drive seems to have some Hash errors with a few BDs.
So I would try my older Verbatim Pioneer.
Can you help me to unleash it for UHD?
Thank you in advance from Germany
SeK<<
OS device name: E:
Revision: 1.14
Serial number: ...
Firmware date: 2020-06-15
Highest AACS version: 76
Firmware version: 1.14
SeK<<
OS device name: E:
Revision: 1.14
Serial number: ...
OS device name: I:
Revision: 1.14
Serial number: ...
Highest AACS version: 50
Can I have the instructions to cross-flash to UD04, please?
baliw wrote: ↑Sun Apr 27, 2025 6:48 pmThis is from a verbatim external, just purchased from retail.Code: Select all
Drive Information OS device name: I: Manufacturer: PIONEER Product: BD-RW BDR-UD03 Revision: 1.14 Serial number: ... Firmware date: 2020-06-15 Bus encryption flags: 1B Highest AACS version: 50 LibreDrive Information Status: Enabled Drive platform: RS8511 Firmware name: PIONEER BDR-US03 Firmware type: Original (unpatched) Firmware version: 1.14 DVD all regions: Yes BD raw data read: Yes BD raw metadata read: Yes Unrestricted read speed: Yes No disc inserted
sure email me that drive info email belowSektorX wrote: ↑Sun Apr 27, 2025 5:52 pmHello Billy,
SeK<<
OS device name: E:
Revision: 1.14
Serial number: ...
Hi, i've got an offer for an old Verbatim external drive with this specs:
Revision: 1.11
Serial number: SHDL258139WL
Highest AACS version: 81
Is it possibly to crossflash it to UD04 ?
Thx
Revision: 1.11
Thx
Yes, I think. You should also post your "Drive platform" and firmware date.
Libre status enable
Drive plattform Rs8511
Firmware name Pioneer BDR-US03
Firmware 1.11
Firmware-Date: 2018-11-28
Drive Platform: RS8511
Firmware 1.11
Hi, Can I please have my drive flashed too
OS device name: H:
Revision: 1.11
Serial number: <redacted>
Highest AACS version: 71
Thank you
OS device name: H:
Revision: 1.11
Thank you
Is it possible to flash this drive?
Laufwerksinformation
OS-Gerätename: D:
Aktuelles Profil: BD-ROM
Produzent: PIONEER
Produkt: BD-RW BDR-UD03
Revision: 1.14
Serienummer: ...
Firmware-Datum: 2020-06-15
PM sent.jan2896 wrote: ↑Fri May 02, 2025 10:52 amIs it possible to flash this drive?Code: Select all
Laufwerksinformation OS-Gerätename: D: Aktuelles Profil: BD-ROM Produzent: PIONEER Produkt: BD-RW BDR-UD03 Revision: 1.14 Serienummer: ... Firmware-Datum: 2020-06-15 Markierungen der Bus-Verschlüsselung: 1B Highest AACS version: 81 LibreDrive Information Status: Enabled Drive platform: RS8511 Firmware name: PIONEER BDR-US03 Firmware type: Original (unpatched) Firmware version: 1.14 DVD all regions: Yes BD raw data read: Yes BD raw metadata read: Yes Unrestricted read speed: Yes
