For the life of me I can not find where to check the enc box so I can flash my drive. My Drive is as follows and shows it can be updated to do this.
LG Electronics WH14NS40 14X Blu-ray/DVD/CD Multi compatible Internal SATA Rewriter Drive, BDXL, M-DISC Support, Black
Where is that box I check..
Trying this for first time.
Re: Trying this for first time.
Are you using the most recent version of the SDFtool Flasher?
Duramax6.6l
Well I figured out what is going on, I purchased and lg drive on Amazon that is listed in my first post. The drive says M-Disk LG and Blue Ray Disk on the drawer that opens up. All stickers on the drive say its an LG WH14NS40 drive.
But when checking the drive with MakeMKV it says that it is an ASUS Drive 12D2HT and it says that it has everything enabled for ripping, LibreDrive included..
I have encoded three disk so far with what seems as no problems..
This drive I think someone flashed and sent back to Amazon. See attached images.. Can this be flashed to the correct firmware or should I send the drive back and get another one.
- UTF-8Image.jpg (511.45 KiB) Viewed 6879 times
- Drive Info.jpg (51.21 KiB) Viewed 6879 times
